Headers Install
Old Dec 5, 2008 | 03:54 PM
Billysc5's Avatar
Billysc5
Default Headers Install
Looking for those of you that have installed headers...are there any that can be installed from the top down on both sides and only using jack stands ? or I'm I going have to use a lift of some kind?
Old Dec 5, 2008 | 04:14 PM
oaks99's Avatar
oaks99
send a pm to FactoryRaceCar i'm pretty sure we did his on jack stands 1 from the top and 1 from the bottom ; but that has been along time ago and i'm to old to remember everything
oak
Old Dec 5, 2008 | 04:19 PM
montac's Avatar
montac
I did my AR 1-7/8 headers from the bottom on jackstands without much issue.
Old Dec 5, 2008 | 04:21 PM
FKING1's Avatar
FKING1
B&B Tri Flo shorties, one from top & one from bottom on stands.
Old Dec 5, 2008 | 04:23 PM
Hrdtop00's Avatar
Hrdtop00
I installed mine in my garage using jack stands & floor jack. One side installed from the top & one from the bottom. If memory serves me correctly, I believe you have to get the front of the car around 22-24 inches off the floor. I installed LG Streets. Just take your time & it's not too bad.
Old Dec 5, 2008 | 04:57 PM
GKE's Avatar
GKE
I installed my LG streets using jack stands. One from top, one from bottom. They go right in and were easy to do.
Old Dec 5, 2008 | 05:33 PM
slowtealz28's Avatar
slowtealz28
Installed SSAC's on a lift, passengers side in from the top by just removing 2 coil packs, drivers side in from the bottom by moving alternator and taking off 3 coil packs. Neither side required the valve covers to be removed.
Old Dec 5, 2008 | 05:53 PM
Billysc5's Avatar
Billysc5
Thanks for the info, sounds like I'l fire up the furnace in the man cave and have at it.
Old Dec 5, 2008 | 07:48 PM
Slow Z06's Avatar
Slow Z06
Kooks went in from the top. Using jack stands and a jack to lift motor
Old Dec 5, 2008 | 08:24 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Long tube header installation instructions:
http://www.ls1howto.com/index.php?article=29
http://97vette.com/howto/headers/index.html
Short tube header installation instructions:
http://www.bbexhaust.com/car/corvett...stall/headers/
http://www.bbkperformance.com/produc...er-system.html
Old Dec 5, 2008 | 08:36 PM
jrose7004's Avatar
jrose7004
We used a 2 post lift on my cousins.
Old Dec 6, 2008 | 01:15 AM
striper's Avatar
striper
I also did LG streets on jack stands with floor jack. Left from bottom and right side from top. Not hard just time consuming.
Old Dec 6, 2008 | 11:22 AM
Ryan040675's Avatar
Ryan040675
So that's it? I've been shying away from this mod on my Vette because of the experience I had putting headers on my LT1 F body. That was a good 8 hours of pain and displeasure. Just like the tune up.
Old Dec 6, 2008 | 11:40 AM
dankhts's Avatar
dankhts
Originally Posted by Mike98SilVert
AH-SUM write up! Great instructions... one of the best explanations on any install I've seen to date!!
To Headers Install
