I Added 22% More Nitrogen and No Sensor Problems
Composition of air (% by volume):
Nitrogen (N2): 78.09%
Oxygen (O2): 20.95%
Argon (Ar): 0.93%
Carbon dioxide (CO2): 0.038%
Others (less than 0.002% each): Neon (Ne), Helium (He), Krypton (Kr), Hydrogen (H2), Xenon (Xe).
As far as being an aircraft mechanic, you obviously don't work much with aircraft having pressurized nitrogen vessels, such as brake accumulators. These have a standard pressure at a given temperature (Usually 70F,) but, surprise, surprise, an adjustment for temperature, because nitrogen increases pressure with temperature, like every other gas known to man. It's used in tires because lack of water vapour means no ice formation in the tires at high altitude.
Oxygen (O2): 20.95%
Argon (Ar): 0.93%
, But it seems to work good on our T-38's down here!!Last edited by talon104; Dec 6, 2008 at 09:14 PM. Reason: more info
As far as Nascar using nitrogen, in their case the tires heat up tremendously and a half pound makes a difference in handling at 200 mph. Your tires won't even get hot to the touch, the difference in pressure will be so small that you won't even notice it. Remember, you only replaced 22% of the total with nitrogen.
I couldnt put it any better myself...
Yes they do expand, but the pressure differential between sea level and outer space is 14.7 pounds per square inch (psi).
if you was to remove 14.7psi on the outside of the tire, the stresses would be the same if you added 14.7 psi on the inside of the tire.
Most tires can take over inflation of 15psi with no problem.
For aircraft tires there is a larger pressure increase due to heating on landing, (notice big black skid marks on runways). As a gas is heated the pressure increases.
For nitrogen, the theory is that nitrogen is approximately 6 time larger than oxygen, therefore is less likely to leak out or through a tire. Therefore a tire filled will nitrogen will hold the same pressure longer than air. But since air is already approximately 80 percent nitrogen, is the cost justified? Might I add that compressed air or any form of air for that matter contains oxygen. Oxygen is what? Its not only corrosive but will spontaneously combust. Thus the reason many jet powered aircraft has an NIU (Nitrogen Inert unit) that steadily removes oxygen from the fuel tanks and replaces it with nitrogen.
I think I have had this arguement here with some fighter pilot before that has probably never turned a wrench in his entire life. No reason in starting it back up. Have a good one.
GM's Position on the Use of Nitrogen Gas in Tires
General Motors does not oppose the use of purified nitrogen as an inflation gas for tires. We expect the theoretical benefits to be reduced in practical use due to the lack of an existing infrastructure to continuously facilitate inflating tires with nearly pure nitrogen. Even occasional inflation with compressed atmospheric air will negate many of the theoretical benefits. Given those theoretical benefits, practical limitations, and the robust design of GM original equipment TPC tires, the realized benefits to our customer of inflating their tires with purified nitrogen are expected to be minimal.
The Promise of Nitrogen: Under Controlled Conditions
Recently, nitrogen gas (for use in inflating tires) has become available to the general consumer through some retailers. The use of nitrogen gas to inflate tires is a technology used in automobile racing. The following benefits under controlled conditions are attributed to nitrogen gas and its unique properties:
• A reduction in the variance of Tire Pressures with temperature changes due to reduction of water vapor concentration.
• A reduction of long term rubber degradation due to a decrease in oxygen concentrations.
Important: These are obtainable performance improvements when relatively pure nitrogen gas is used to inflate tires under controlled conditions.
Nitrogen inflation can provide some benefit by reducing gas migration (pressure loss) at the molecular level through the tire structure. NHTSA (National Highway Traffic Safety Administration) has stated that the inflation pressure loss of tires can be up to 5% a month. Nitrogen molecules are larger than oxygen molecules and, therefore, are less prone to "seeping" through the tire casing. The actual obtainable benefits of nitrogen varies, based on the physical construction and the materials used in the manufacturing of the tire being inflated.
Another potential benefit of nitrogen is the reduced oxidation of tire components. Research has demonstrated that oxygen consumed in the oxidation process of the tire primarily comes from the inflation media. Therefore, it is reasonable to assume that oxidation of tire components can be reduced if the tire is inflated with pure nitrogen. However, only very small amounts of oxygen are required to begin the normal oxidation process. Even slight contamination of the tire inflation gas with compressed atmospheric air during normal inflation pressure maintenance, may negate the benefits of using nitrogen.
Now to be totally honest, the tires I have on the C5 are not new, nor are the sensors in the tires new. So, to really test the results one should put new tires and new sensors on their C5 and start with a virgin application, IMO.
