Question for GHL Guys
Old Dec 8, 2008 | 07:06 PM
rwsr50's Avatar
rwsr50
Default Question for GHL Guys
I hear talk of a motor boat idle with some exhausts, but what about motor-boat-like water output??? Maybe I just never noticed it before with the stock exhaust, but with the new GHL Bullets, it seems like the exhaust is putting out a lot of water when I start it up cold after sitting for a week or so. I mean it shoots out of the tail pipes onto the floor, and puddles lay in the tailpipe tips.
The car hasn't seen much driving since the weather started getting ugly, so I start it and run it every couple weeks to keep the battery charged and all. I run it long enough to reach operating temperature, and vary the speed so it isn't just idling. At first I figured it was just condensation from the colder weather, but I don't recall seeing this last winter with the stock exhaust. Anybody else with GHL Bullets notice this being different than with the stock exhaust?
Old Dec 8, 2008 | 08:39 PM
Ltrain925's Avatar
Ltrain925
The GHLs have more room inside for moisture to get in and build up condensation since there isn't as much sound dampering material inside as the stock TI exhaust, just my guess not quite sure though
Old Dec 9, 2008 | 10:57 AM
jovette's Avatar
jovette
I know my '00 spits water vapor out when cold, but never really gave it any thought....just seems normal for a cold V8 engine with dual exhaust system. Love my GHL Bullets though
Old Dec 9, 2008 | 11:06 AM
Jims79's Avatar
Jims79
All normal in cold weather even when its cool out normal...
Old Dec 9, 2008 | 12:43 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Stainless Steel...
BTW, starting and letting it warm up is not such a great idea...
Peace
Chip
__________________
..................Click for
Old Dec 9, 2008 | 06:06 PM
rwsr50's Avatar
rwsr50
Originally Posted by Willfulone
Stainless Steel...
Peace
Chip
Why?
Old Dec 9, 2008 | 08:04 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Why?
carbon build up...should be driven
Oh and my GHLs does the same thing wit hthe water thing, no harm no foul
Old Dec 9, 2008 | 08:33 PM
rwsr50's Avatar
rwsr50
I figured when I can't drive it due to all the crap on the roads (snow, salt, cinders, etc.), running it is better than just letting it sit. Like I said, I vary the engine speed, and make sure it gets to full temperature.
Old Dec 9, 2008 | 08:37 PM
CCA Corvette Parts
Heat cycling your car also causes condensation...everywhere...
The best thing to do for long term storage, is to top off all the fluids, fill the gas tank, put a battery charger/tender on it and cover it up...
Peace
Chip
Old Dec 9, 2008 | 10:22 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
When I lived in NY and hadn't driving the car for 3 weeks maybe a month, Id start the C5 and let the fluids cycle some while I shoveled the drive way.
If it was a sunny weekend day, no ice or melting snow, 15 degrees out, Id take it for a spin to bust the rust off the rotors.Now in Tampa, the car sits just as long because I dont have time to drive it. I always start it up and let it warm up for a couple minutes.
I to get some water flow out my GHLs, but I notice more from the start up explostion, and when driving. Actually I used that excuse and oil burning to have the motor rebuilt6 months after I got it.
Old Dec 10, 2008 | 11:54 AM
rwsr50's Avatar
rwsr50
Peace
Chip
Chip, what is the difference from driving the car where it heats up then cools down after you park it. I thought by letting it thoroughly warm up, I was drying up all the condensation before shutting it down.
Old Dec 10, 2008 | 01:48 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I believe that I read that the engine "oil temp" is the issue here and should be driven to reach optimum effect and burn off any condensation in the crankcase and upper end oil passages.
Old Jun 11, 2009 | 04:13 PM
sbadd99's Avatar
sbadd99
BB quads do the same thing its not a problem
Old Jun 11, 2009 | 05:27 PM
WKMCD's Avatar
WKMCD
It's been raining a lot around here lately. I don't see any puddles on the roads and it hasn't gotten over 80 degrees. Where do you think they went?
Think about it.
To Question for GHL Guys
