may not work because of the way you have to twist the exhaust as it comes out.. just cut it off... you can always have it welded back together if for some reason you want to re-install it... I have successfully removed stock C5 exhaust on 3 occasions using a jack, block of wood, and adjustable jack stands, so it is possible to do on the garage floor... you just have to remove the sway bar brackets... not a big deal at all
