Corbeau Forza (help please)
Old Dec 9, 2008 | 05:59 PM
Torch FRC's Avatar
Torch FRC
Default Corbeau Forza (help please)
About to pull the trigger on some Forza wides ( I have a 38 waist ) probably wont fit in the standard 36. Will it fit in the car? Please advise.
Old Dec 9, 2008 | 10:04 PM
Torch FRC's Avatar
Torch FRC
ttt
Old Dec 10, 2008 | 01:56 AM
Last C5's Avatar
Last C5
My guess is that you will fit in the standard Forza and it will fit in the car just fine. The wider Forza is going to require you to shim the outboard seat mounts (not rail mounts) if you want the upper seat ears (shoulder supports) to clear the doors and it will be a very tight fit for the car.
Old Dec 10, 2008 | 02:13 AM
Higgs Boson's Avatar
Higgs Boson
I have the Forza regulars in the car but I am a 32-33 inch waist (6ft). I would not recommend them to you unless it is a track car. They sit very upright, non-adjustable, etc. I have a Z06 and the stock seats were lighter than the Forzas. The only heavy thing was the driver side elec motor..... Just my 2.
Old Dec 10, 2008 | 02:59 PM
Last C5's Avatar
Last C5
I sort of agree. I run the FX1 and FX1 Pro and they aren't a seat I would use for a daily driver. However, mine were much lighter that the stock seats and I mounted them on the Corbeau sliders so they are adjustable front and back.
Old Dec 10, 2008 | 04:34 PM
Torch FRC's Avatar
Torch FRC
Thx for the replies............^^^^^What waist size are you? I dont wanna buy the seat and be uncomfortable. I measured the wide specs from the corbaue website and there is no way its gonna fit.
Old Dec 10, 2008 | 06:18 PM
Last C5's Avatar
Last C5
Unfortunately, the specs don't tell the whole story on those seats. I originally installed FX1s and they were way to large. I traded out the driver's seat for an FX1 Pro which is 1 1/2" narrower and it fits me perfectly. My waist size is 36/37" My older spec book on the Corbeaus shows the Forza fitting up to a 36-38" waist with the Forza being only 1" narrower than the FX1.
To Corbeau Forza (help please)
