[Z06] head/cam
Old Dec 10, 2008 | 09:43 PM
DANZGLASS's Avatar
DANZGLASS
Default head/cam
changed heads got some stg 2.5 5.3's from texas speed
cam 230/232 .592/.595 111lsa[/B]
other mods will be:
dynatech headers high flow cats and x pipe
slp loudmouths
blackwing
ported oil pump
ls2 timing chain
svo 30's
stock ls6 intake/tb
rps twin friction clutch kit
I just want to know what you think about the tunability of the cam for a daily driver. Also what you think think it could make. tj wong in vancouver wa.
looking for 430-440whp
Old Dec 10, 2008 | 09:57 PM
DANZGLASS's Avatar
DANZGLASS
ps cam and springs only have 500 miles on them. He spun a rod bearing on the dyno. He was building a 370 forged on the side decided might as well put it in.
Old Dec 10, 2008 | 10:04 PM
gasboy's Avatar
gasboy
very streetable with the right tune.my guess on rwhp is around 450.
Old Dec 10, 2008 | 10:36 PM
bullitt4110's Avatar
bullitt4110
should be very drivable and with the higher compression I would think between 440-450
Old Dec 10, 2008 | 10:41 PM
DANZGLASS's Avatar
DANZGLASS
He told me he had the cam ground to go with the heads so I think they will work well.
Old Dec 11, 2008 | 11:14 AM
DANZGLASS's Avatar
DANZGLASS
Read your post. I would save and buy LG pro's or ARH's, or Kooks, all 1 3/4. Also, you say the heads are just ported and polished, I assume then they aren't milled and have the 65 cc heads. The smaller head gasket won't really do that much for you.
Keeping your LS6 intake and TB, with that cam, the streets, you really will be around 400 at best.
On a 114 LSA, you really need plus 4. The plus 2 will hurt you. The ICL on these engines are whats needed to be 110 or less to 109.
Since your doing all this, save just a few more bucks, call Vengence Racing, or LG motorsports. Maybe A&A corvette, as these guys will be honest with you.
On your heads, just above where the plugs are, if it looks like an X pattern, these are good heads, as GM had 3 vendors. The cold cast heads have an X pattern which gave the best runners, intake and exhaust.
This difference in heads, on 02-04 Z06's are the main reason why we see some dynoing about 330-335 rwhp verus's 345-350 rwhp.
Just trying to help. Good luck.......
I just got this pm woundering what you guys think is this guy true think I will only make 400whp that seems low. Any others want to give me some thoughts?
Old Dec 11, 2008 | 12:22 PM
DANZGLASS's Avatar
DANZGLASS
Can anyone tell me if this guy is right?
Old Dec 11, 2008 | 08:13 PM
DANZGLASS's Avatar
DANZGLASS
bump
Old Dec 11, 2008 | 08:17 PM
golfinz's Avatar
golfinz
Thats a very big split for an n/a cam. I would stick to between 4-6 degrees between the intake and the exhaust duration. You will make more than 400rwhp, however. Just make sure your P/V clearance is good since you are running a small head gasket
Old Dec 11, 2008 | 08:38 PM
DANZGLASS's Avatar
DANZGLASS
I was planning on running a different cam. But he told me the cam was ground to work with the porting of the heads. I could always sell it and get a different cam.
Old Dec 11, 2008 | 08:46 PM
DANZGLASS's Avatar
DANZGLASS
what effects will having a big split be?
Old Dec 11, 2008 | 10:10 PM
VIPERBLUELX's Avatar
VIPERBLUELX
too much split in the duration, that looks like a blower cam
I'd sell that cam and gets something without so much split. I'm running a 228/232 111+2 which was custom ground for my ported heads. I'd look for something closer to those specs if I were you.
There's nothing at all wrong with the LG streets, so don't worry about that.
ported 243's with a .040 gasket work well even without milling, I gained 32rwhp with that setup and still have good p/v clearance without having to flycut
Old Dec 12, 2008 | 08:34 AM
Kurtomac's Avatar
Kurtomac
im with him ^ danzglass your PM guy is wrong.....youll have plenty of compression, you wont have to flycut and youll get a good gain at a good price....also with viper on the cam....ill sell you my 236 238 601 605 113+2 cam....im wanting something a little different with different lobes
Old Dec 12, 2008 | 08:49 AM
DANZGLASS's Avatar
DANZGLASS
if I get a different cam it will be more like vipers cam. I am going to ask the guy to just send the heads and pushrods and send me back some money for the cam.
Old Dec 12, 2008 | 09:18 AM
DANZGLASS's Avatar
DANZGLASS
this cam is for sale in the forum looks good I may try to get it 230/232 .592/.595 111 lsa
Old Dec 12, 2008 | 10:24 AM
VIPERBLUELX
that cam would certainly be better
Old Dec 12, 2008 | 12:36 PM
DANZGLASS's Avatar
DANZGLASS
talked with the guy will be getting the other cam tonight.
To head/cam
Old Dec 12, 2008 | 02:12 PM
golfinz's Avatar
golfinz
Good move IMHO
Old Dec 12, 2008 | 02:14 PM
DANZGLASS's Avatar
DANZGLASS
only want to do this once. Last thing I need is another 1500 labor for a second cam swap!
Old Dec 12, 2008 | 03:11 PM
Ryan L's Avatar
Ryan L
Patrick G or Predator XFI cam? My 224/230 XFI makes as much power as the XERs in the low to mid 230s duration.
