Cold start engine rap - does anything help?
Old Dec 19, 2008 | 10:49 AM
  #61
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by Greg Gore
There is no oil, nor oil filter, nor oil tricks that will quiet a noisy piston.
Greg,
That's been my argument all along. Your detailed explanation can not be disputed in any way. Thanks for reaffirming my thoughts on this.
-QSV
Old Dec 19, 2008 | 11:06 AM
  #62
duane ratliff's Avatar
duane ratliff
Default new engine design
Originally Posted by Chevy-SS
Just bought a 2004 C5 coupe with auto and 15K miles. It has a very noticeable rapping when cold. I probably shouldn't have bought the car, but I test drove it when warm and there was no rapping. The engine really has to warm up before the rapping goes away. I'm disappointed the seller never mentioned this.
I'm assuming it's a piston which is a loose fit to its' bore, and I know there are issues about GM piston fitment. I also realize that alum pistons expand/contract at different rates than steel blocks. I've owned plenty of other Chevy cars which made the cold engine noise, but this one seems kinda bad.
Are you guys using any special oils or additives which reduces this rapping?
thanks
the 1997 up corvette engine was a all new engine designed for long life under hard driving ! there are plenty of litature on the LSI engine . the entire engine is the best ever built by general motors ! the pistons have floating wrist pin for long life at hard driving ! the floating wrist pins are the source of the noise everyone hears while the engine is cold . if they continue to rattle when warm you have problems with most any moving parts ? back in the 60's Jahns pistons was one of the 1st to sell these floating wrist pin pistons an they were super high dollar as they were mostly high compression up to 13.5 compression an were indestructive or worth thier money ! these pistons needed to be warm to be quiet as they were clearanced to make more H.P. with less friction. if you let the vette engine warm up the noise will go away . the LSI is the best engine ever built in my opinion . use good oil an warm the engine to normal temp. an hold the pedal to the metal ! it's made to take the R.P.M. duane # 122540 born 3/6/00 SSR # 6363 born 3/02/04 just my humble opinion !!
Old Dec 20, 2008 | 05:27 AM
  #63
NC99's Avatar
NC99
Floating wrist pins are not the source of the noise. If that were the case, every single LS1 with floating wrist pins would have it. Could you imagine the noise at any LS1 event? Would sound like a truck stop.
My 2002 had it. My 1999 does not.
Old Dec 20, 2008 | 05:39 AM
  #64
homewrecker's Avatar
homewrecker
hey!!! my 98 makes that piston slap noise
Old Dec 20, 2008 | 08:58 AM
  #65
Chevy-SS's Avatar
Chevy-SS
Originally Posted by NC99
Floating wrist pins are not the source of the noise. .......
