[Z06] clutch making a noise
Old Dec 14, 2008 | 10:20 AM
roadkingtexas's Avatar
roadkingtexas
Default clutch making a noise
clutch is making a noise when it is depressed, what could this be,,,
Old Dec 14, 2008 | 10:25 AM
z060-0's Avatar
z060-0
Throwout bearing for sure.
Old Dec 14, 2008 | 12:15 PM
lbarnard's Avatar
lbarnard
Also if the pilot bearing is worn you will get some play which will lead to a noise. In You'll find out more once you tear into it. Does it make noise when you are in neutral without clutch pushed in? Just a reminder if you don't have one install a remote clutch bleeder!
Old Dec 14, 2008 | 12:22 PM
roadkingtexas
no it only makes noise when u depress the clutch just for a sec then it is quite....
Old Dec 14, 2008 | 12:38 PM
lbarnard's Avatar
lbarnard
I had the same problem. How many miles on the clutch? If you are not making over 500 and don't drag race the car an LS7 clutch would be a good choice. I have one in my car and I track it as well.
Old Dec 14, 2008 | 12:40 PM
roadkingtexas
the car has 69000 miles on it,, not sure if it is the original clutch or not..
Old Dec 14, 2008 | 12:43 PM
lbarnard's Avatar
lbarnard
Not bad if it is; it's just a PIA putting one in.
To clutch making a noise
