Lowering Bolts???
Old Dec 16, 2008 | 12:28 PM
cammedvette's Avatar
cammedvette
Default Lowering Bolts???
My son is wanting to get me the front and rear lowering bolt kits for Christmas. I like the look of the lowered rides, just want to know if this will effect the alignment. Do I need to worry about re adjusting the alignment of either the front or rear after install??
Old Dec 16, 2008 | 12:37 PM
hotwheels57's Avatar
hotwheels57
The lowering procedure will usually require a complete 4 wheel alignment to avoid premature wear of the tires...
Old Dec 16, 2008 | 12:44 PM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
Just lowered mine on stock bolts. I'll be taking it in for an alignment after I put some miles on it to let it settle. Of couse being winter, that could be quite some time.
Old Dec 16, 2008 | 12:55 PM
snake0824's Avatar
snake0824
Ihave lower mine on stock bolts and about 500 miles later and the tires wear is fine so far and drive straight down the road
Old Dec 16, 2008 | 01:11 PM
hotwheels57
It may depend more on whether the car being lowered is a standard coupe/convertible or the Z06.
The latter had a more aggressive alignment from the factory, so lowering it may have more of a negative effect.
My car is lowered on oem bolts and bushings (3/4" maximum). My alignment was off significantly requiring the alignment after a few miles to settle.
It also depends on whether the car is lowered on oem bolts/bushings or longer bolts and/or cutting or complete removal of the bushings to enhance the effect.
Old Dec 16, 2008 | 01:27 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Another issue is whether the car is an FE1 (base) suspension, or a Z51 suspension as to how low you will get on stock bolts. Either way, with the price of tires for the C5s a good 4 wheel computer alignment is always a good idea. IE; why do a half *** job to save about $90? Do it right or don't do it at all. A shorter body (Bilsteins where my choice) shock should be used also. Again, do it right, or just don't do it.
Old Dec 16, 2008 | 01:44 PM
cammedvette
Default Lowering Bolts?????
Just to clairify...I am talking about the aftermarket lowering bolts. Not sure if there longer or what. The rear bolts come with new bushings. From what I read you should get up to 1 1/2" lower with these kits.
Old Dec 16, 2008 | 02:11 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
In general the aftermarket bolts will lower the car more than stock bolts. I would get an alinement for sure.
Old Dec 16, 2008 | 02:44 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Most of the kits are longer grade 8 bolts - and I believe they are 8" long as opposed to the stock 6" bolts. My opinion - lower it on the stock bolts first, and see how you like it. No need to buy anything to lower it on the stock ride height adjustment bolts. I would agree to get a good four-wheel alignment when done.
Old Dec 16, 2008 | 08:29 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
Old Dec 16, 2008 | 09:28 PM
happa's Avatar
happa
Mine is lowered on longer bolts rear and I took out the front bolts. Yes i took them out, wanted as low as I can, I have no issue for over 4 years now. alignment is a MUST! Also you might want to consider better shocks too. heres some pics of mine
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Dec 16, 2008 | 09:56 PM
patsfan's Avatar
patsfan
From: Swanton VT 2000 Navy Blue Mettalic M6 / 1991 Auto - Steel Blue 68,500 R.I.P
Old Dec 16, 2008 | 10:27 PM
Dave Sweatt's Avatar
Dave Sweatt
Even lowering on the stock bolts took mine out far enough to be out of spec. I agree with an alignment being done after it all settles.
Old Dec 16, 2008 | 11:36 PM
Indy's Avatar
Indy
Just so you know, even lowering on stock bolts will drop your Vette quite a bit. I scrape everywhere I go, even leaving my driveway (and my driveway is pretty much straight...). Of course with longer bolts, you have a bigger range to experiment with.
Old Dec 16, 2008 | 11:39 PM
jrose7004's Avatar
jrose7004
Drive it a couple of hundred miles and align it.
Old Dec 17, 2008 | 12:45 AM
mellowyellow01vert's Avatar
mellowyellow01vert
I replaced my OEM shocks and swaybars with C6 ZO6 shock and sways, and lowered the car on the stock bolts. Very nice ride and cornering. I am running General Exclaim UHP tires, and they stik very nice on Dry or Wet roads.
I agree that you need the correct tire for your driving conditions. Hard "runflats" are not going to work in cold climates, neither are short-fat tires. Look to the past for answers....
Not so many years ago, we all changed our tires in the Winter, to "snow tires".
If you must drive your Vette during the winter, then get yourself a set of Camaro wheels with snow tires on them or at least good all-weather tires.
JB.
Old Dec 17, 2008 | 12:58 AM
tricep's Avatar
tricep
St. Jude Donor '09
Originally Posted by happa
Mine is lowered on longer bolts rear and I took out the front bolts. Yes i took them out, wanted as low as I can...
Me too! Removed the fronts, long ones in the back. It can go even lower if I wanted to, but then I would have a sled
Speed bumps are NOT my friend.
To Lowering Bolts???
