Shocks Inoperative 80mph Maximum Speed
Old Dec 16, 2008 | 03:22 PM
IDM's Avatar
IDM
Default Shocks Inoperative 80mph Maximum Speed
The other day I was doing some work underneath the car, I accidentally bumped off the connection going to the EBCM. I found out why it easily came off. The handle on top that locks it into place wasnt able to lock down because a pipe from the supercharger was blocking it. So I removed the plastic handle piece and shaved off the obstructive corner and put it back. Locked the connector into place and started the car and got the shocks inoperative warning as well as service ride control and service engine soon. I disconnected my battery over night and the same thing this morning. How could have taking out a connector and plugging it back in done anything? Is there a certain process I have to go through now to retrain it or get rid of the codes?
Thanks for any input here
Old Dec 16, 2008 | 03:54 PM
day3165's Avatar
day3165
bump...
Old Dec 16, 2008 | 06:42 PM
IDM's Avatar
IDM
Thanks for the bump
Old Dec 16, 2008 | 08:01 PM
dobewillie's Avatar
dobewillie
this is going to be interesting
Old Dec 16, 2008 | 08:15 PM
Tim01Coupe's Avatar
Tim01Coupe
Just a guess, but how about if the shocks really are inopperative??
Did you go through your grounds?
I would look at grounds near the spot you were meddling with. It may not be the plug at all.
Was there a previous owner who had the plug unplugged for a reason?
Old Dec 16, 2008 | 08:19 PM
IDM's Avatar
IDM
Well while the message is displaying on the DIC I know the shocks ARE inoperative!
I unplugged the connector to the ebcm on accident while I was working and when I noticed I plugged it back in and tightened everything down. I dont think there are any grounds in that area, it's an 01 so the ebcm is right in the front of the engine. No the previous owner didnt do anything the car was fine until I was routing a boost hose in the area.
Old Dec 16, 2008 | 08:24 PM
Patches's Avatar
Patches
That is an F45 error message as the standard shocks don't have any electrical connections to feedback to the BCM. Do you have the F45 suspension package? If so, check all the electrical connectors to the shocks to ensure they are tight. Also, check the console switch - if it's between settings, it will generate an error message.
Old Dec 16, 2008 | 08:36 PM
IDM's Avatar
IDM
Patches yes I have the package that lets you choose between tour, sport and high performance. The console switch wasn't the culprit. The connector to the ebcm is tighter than it was ever before. There was one shock that had a connector wire that was out of place and I tucked it under.
Would one shock being disconnected throw this message? Would the ebcm being disconnected through this message?
Thank you!
Old Dec 16, 2008 | 09:02 PM
Patches's Avatar
Patches
A faster way to diagnose this issue would be to collect the trouble codes from the DIC and post them here. Then I can determine what the next step is, if there is one, as it could be a temporary error message that was generated by a transient or intermitent occurance. The Electronic Brake Control Module (EBCM) module is not directly associated with the Electronic Suspension Control (ESC) module that oversees operation of the suspension system. THE ESC module is in the rear driver storage compartment.
The ESC controls the damping mode selection according to the following factors:
  • The vehicle speed
  • The chassis pitch input
  • The steering position
  • The body to wheel displacement
  • The ride control switch position
The ESC module evaluates these inputs in order to separately control the solenoid valve position in each of the shock absorbers. If you look at the inner wheel well, you'll see a position sensor attached to the body and the control arm. That sensor feeds back to the ESC which uses the data to adjust that particular shock.
Old Dec 16, 2008 | 09:55 PM
IDM's Avatar
IDM
  • The vehicle speed
Patches! Your post just brought something else to my attention, I had a gallon of distilled water stored on top of the drivers side storage compartment. A couple days ago I noticed that half of it was gone and there was a pinhole that had formed in the gallon of water. That area is wet from half a gallon of water spilling. Looks like it's very possible that I got that module there wet and broke it from what you said!
I am going to search on how to pull codes and list them.
Thank you for your help.
Old Dec 16, 2008 | 11:19 PM
IDM's Avatar
IDM
I had felt the carpet a couple days ago and it felt damp but nothing too terrible to so I didn't go further but to open up the trunk to let it vent and dry. Tonight I removed the storage cover and there was a light film of mold that had grown on it and things are damp in the area. The esc module seems dry and all the connectors are tight on it.
Here are all of the codes my car had. I didnt catch the prefixes I hope I didnt have to as it was moving too fast.
c1226
c1283
rtd no comm.
u1096
b2238
b2282
b2284
u1064
u1096
b2283
b2285
u1096
c2100
c2110
d2115
u1000
u1255
u1064
u1096
u1096 was listed 4 separate times and u1064 2 times, not sure if those are different codes when it lists it twice
Old Dec 17, 2008 | 04:15 PM
IDM's Avatar
IDM
ttt
Old Dec 17, 2008 | 08:38 PM
Patches's Avatar
Patches
None of those codes are relevant to the suspension control; however, the "rtd no comm." indicates the Real-Time Damping system - the F45 suspension control module - lost communication with the serial data bus.
You should take down the entire code when you read them from the DIC. The C indicates that it's current while an "H" indicates it's history and not currently active.
The U codes are explained here:
DIC Onboard Diagnostics Show DTCs U1016, U1064 and U1096 in History #PI00043 - (Jun 19, 2002)
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
DTCs U1016, U1064 and U1096 may be present when scrolling through the onboard diagnostics via the instrument cluster Driver Information Center (DIC).
Recommendation/Instructions:
This is a normal software function as long as the DTCs have a history status upon ignition cycling. No repair attempts should be made.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance. This diagnostic approach was developed for the vehicle with the VIN you entered and should not be automatically be used for other vehicles with similar symptoms.
Here are the others:
C1226 Wheel Speed Sensor Circuit
C1283 VSES Sensors Uncorrected
B2238 Door Lock Switch Circuit
B2282 Battery #1 Circuit
B2284 Battery #1 Circuit
B2283 Battery #1 Circuit
B2285 Battery #2 Circuit
C2100 ?
C2110 ?
D2115 ?
There are a host of RTD codes that could be set but your list contains none of those codes. It appears, at this point, that your control module has lost communication with the main serial bus You can start by checking the connectors and the module (perhaps the moisture damaged it) - if you don't find an obvious issue, post again and I can send you the diagnostic from the manual.
Old Dec 17, 2008 | 11:56 PM
IDM's Avatar
IDM
Patches thank you so much for your help.
This is the module that is in the drivers storage area correct?
I've opened the trunk and let it air out in the garage, it appears that the ecu got wet and the moisture has hurt it. Maybe once it dries out it will work again?
I will go back and write down which of these codes are H or C
Old Dec 18, 2008 | 03:01 PM
IDM's Avatar
IDM
ttt
Old Dec 18, 2008 | 09:05 PM
IDM's Avatar
IDM
ttt
Old Dec 19, 2008 | 02:09 PM
Jason Blue Boost's Avatar
Jason Blue Boost
I had that same error message when I converted my F45 system to the new F55. Two wires were not connected right and I couldn't go over 80mph. It sounds like you may need a new F45 ecm if it got wet. I might still have mine if you need one. I sold my shocks years ago and have to check if I still have the F45 ecm.
To Shocks Inoperative 80mph Maximum Speed
Old Dec 19, 2008 | 06:58 PM
Patches's Avatar
Patches
Awesome offer!
Old Dec 19, 2008 | 09:22 PM
IDM's Avatar
IDM
That is a good offer, I'm right now airing out the car in hopes that it'll dry and start working again, if that is even the problem!
I cant believe trying to be prepared with distilled water got me in this case! I dont even drive the car.
Also I had heard that distilled water didn't cause mold and that is not the case as the bottom of the storage cover was moldy.
Would the 98 and 01 ecms be the same for the F45 system?
Thank you
Old Dec 21, 2008 | 11:08 PM
IDM's Avatar
IDM
Hi Patches
I kept the trunk open for 4 days in the garage and when I turn the key to the ON position it still says shocks inoperative!
Does the no communication mean that the ecu is probably messed up from the moisture?
If you could send me the diagnostic portion for this Id appreciate it
