Does Seafoam really work???
http://www.youtube.com/watch?v=2hrasAYG42g
The PCV hose it fine, but any vacuum line will work.
I poured in about 1/2 can through the power brake booster hose using a small funnel. Put the rest in the fuel tank. Engine stumbled a bit while pouring SLOWLY, but it took it w/o a real problem. The smoke started just before I shut the engine down. I let it sit for 5 minutes or so. Started it back up & got some more smoke, but less than I thought I would. What I am getting is a light bellowing of smoke @ idle and a puff when I throttle it harder.
What I noticed fairly soon was that a light, eratic miss at idle seems to be gone. I have 30 gallons of fuel or so to burn up, so I'll report back at the next fill up!
**note** Its worth noting here that I keep my work truck in top working order. I drive it everyday, and sometimes put 150 miles a day on it. I give it tune ups regularly and at the slightest sign of trouble, I repair the problem immediately. It has allot of miles on it, but it runs and looks much younger than it is.
Specs: 1995 Chevrolet 2500 4x4
Throttle Body 350/4L80
169,000 miles
I heard about Seafoam through the F-body forums, and like many was a bit skeptical... but hey for a few bucks why not. I ran it through the TA@ ~95k miles, using the vacuum line method. I actually used a whole can, and holy MOLY!! It looked like a forest fire in my little cul-de-sac. ALL of the neighbors came out to see what was going on. I kept her running and she probably smoked for ~10 minutes, then I went on a little run around the neighborhood, with a NOTICABLE increase in available power.
Being the skeptical person that I am, I wanted to figure out/prove how it could be a hoax. I mean, it could have all been in my imagination that it ran so much better right? "Placebo effect". And how hard would it be to make a liquid that smoked when ignited in a combustion engine? Probably not hard at all. It just so happened the perfect opportunity arose... I had another vehicle of mine, while I was away, break down on my house/car sitter. The dealer was my only recourse, and part of the "fix" was a full fuel system cleanout (to the ridiculous tune of over $500). As soon as I got back, I got a can of seafoam, and performed the exact same procedure that I had done on my TA, to the other vehicle (with even more miles). Absolutely NOTHING came out of the exhaust.
Since then I have used seafoam many many times, and have even used it before an oil change in the crankcase (made relatively clean 3000 mile synthetic look like 10000 mile dino oil). I will continue to use, abuse, and recommend seafoam as long as it's available.
Jon
been the same.
Just my .02 worth.
