i know you can lower a stock vett, but instead or removing the bolts and cutting bushings dont they sell a kit? a bolt kit or lowering kit? i dont wana change out the springs or coilovers, just a bolt kit
if so let me know send me some sites
thanks...
Here's one:
I used the rear bolts and removed the fronts completely
Can't speak for using different bolts and cutting bushings, but just lowering it all the way on stock bolts presents a number of challenges getting in and out of driveways, streets and speed bumps. I wouldn't want to go any any further than that. I think it would be a major pain in the *** most of the time.
It is. Mine is lowered with two bushings cut in the back, and the front bolts are gone. I'm putting the front bolts back on, and they are going on their lowest setting, and two bushings back in the rear.
