Seems that anytime I turn the stalk switch to the first position to try to turn on my fogs (HIDs installed), the headlamps raise as if I turned the stalk all the way to the second position. No matter what I can not get the headlamps to stay down without turning the stalk completely off. Any ideas would be appreciated.
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Sounds like you might need the 55w resistor installed, check with JW Motoring here on the forum and ask him, I installed the resistor and all works fine.
Bill
