Dirty seatbelts!!
Old Dec 26, 2008 | 04:30 AM
speedy-vet's Avatar
speedy-vet
St. Jude Donor '06-'07-'08
Default Dirty seatbelts!!
I hate to see how dirty the seatbelts are!!!
Mine are beige color and I hardly drive the car but the part that is dirty is not the that crosses your chest but the part that roles inside the wall of the car? I tried to spray the carpet cleaner and it wont do anything!
Has anyone deal with this problem? any way to clean them?
Thank you in advance.
Syl
Old Dec 26, 2008 | 07:53 AM
BT-01-vette's Avatar
BT-01-vette
Try a little 409 with a soft scrub brush Syl
Old Dec 26, 2008 | 02:13 PM
VetteBoy1979's Avatar
VetteBoy1979
CI 3-4-8 Veteran
St. Jude Donor '07-'09-'12
Works for me, everytime
Old Dec 26, 2008 | 02:20 PM
Bell's Avatar
Bell
I'm glad mine are black. If you try the 409 as suggested above, please post your results. Did it work for you?
Old Dec 26, 2008 | 03:05 PM
cuspid's Avatar
cuspid
carpet cleaner and white towels to blot.
Old Dec 26, 2008 | 03:16 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Before and after pics would be nice!
Old Dec 26, 2008 | 08:15 PM
dobewillie's Avatar
dobewillie
simple green and rags theres a lot of cleaners that will work for you now get scrubbin
Old Dec 26, 2008 | 08:19 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I've used Griot's Garage Interior cleaner with pretty good success. You might consider using a real soft brush to work the cleaner into it. I would be careful using anything not intended for dyed fabric, as it might affect the color. If you want to try anything like that, you might try it in an inconspicuous place first.
Old Dec 27, 2008 | 09:31 PM
Whatever you end up using, post up the details and pics. Would be interested in this too.
Old Dec 28, 2008 | 01:58 AM
bencini231's Avatar
bencini231
Old Dec 28, 2008 | 11:16 AM
Choreo's Avatar
Choreo
I use the same thing on mine - works great!
http://www.griotsgarage.com/product/...rrivals&page=1
Old Dec 28, 2008 | 11:52 AM
JJ 86's Avatar
JJ 86
Old Dec 28, 2008 | 12:04 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
409 and a brush will work !!
Old Dec 28, 2008 | 12:55 PM
Jet-Jock's Avatar
Jet-Jock
On my C4 (beige interior) I used some warm water and a scoop of Oxyclean. I pulled the belt out completely and blocked it then put towels around the area I worked, using a scrub brush worked the oxyclean solution in, wiped clean with a dry towel, and then let them dry. Doesn't harm the webbed material and they looked like new.
Old Dec 28, 2008 | 12:57 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
i never used my vette since it is a garagequeen so the seat belts never get dirty
speedy-vet
Old Dec 28, 2008 | 01:35 PM
vetterlatethannever's Avatar
vetterlatethannever
I got some dirty seatbelts... I'll try the 409 and see if I can get some before and after pics
Old Dec 28, 2008 | 05:24 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I mix some simple green and water together. Take two clothes pins, pull the seat belt all the way out and then put on clips to stop the belt from retracting.
Spray on the simple green mixture and a nail brush or something similar in size and scrub them up.
Get a pail of clean water and rag and rinse the belts off with the rag and let them sit until they are dry.
To Dirty seatbelts!!
Old Dec 29, 2008 | 02:14 AM
chrisj's Avatar
chrisj
St. Jude Donor '12
My problem is worse. Apparently there is something wrong with the retract mechanism. If I lean out the window to get a parking ticket at a garage, then the dirty belt gets on my shirt. I've cleaned it, but it keeps coming back. Anyone else had this problem. I just wipe it away with a rag and it works for a while.... then it comes back.
chris
Old Dec 29, 2008 | 11:06 AM
bucwheat's Avatar
bucwheat
Any mild cleaner or foam carpet cleaner.
Old Dec 29, 2008 | 05:39 PM
GS Ron's Avatar
GS Ron
This is what I've been doing with the C5 oak interior and the C4 tan before it............No dirt on belt....No stains on shirt
