Corvette Exhaust Plate
Old Dec 26, 2008 | 12:11 PM
HG's Avatar
HG
Default Corvette Exhaust Plate
My wife gave me one for christmas The directions show attaching it using the double stick tape. Just wondering if this holds the plate so it won't fall off in a short time. Would two small SS bolts be better ?? 99 FRC
Old Dec 26, 2008 | 12:19 PM
bartsky's Avatar
bartsky
The tape will hold it just fine. I have never had one come off.
Old Dec 26, 2008 | 12:24 PM
HG's Avatar
HG
OK thanks. I guess the key is getting the area clean before applying the tape.
Old Dec 26, 2008 | 12:25 PM
jobear's Avatar
jobear
Clean the area first with laquer thinner, or similar, and the tape works great.
Old Dec 26, 2008 | 12:26 PM
2CRUZIN's Avatar
2CRUZIN
That is correct, make sure it is clean, then clean it again.
Old Dec 26, 2008 | 12:31 PM
Mad Dog Peter's Avatar
Mad Dog Peter
This sucker is heavy, and the supplied GM tape works great.
But here's a little tip:
You only got one shot to get her on straight, right?
Wrong.
Take some liquid nails and make some small dots on the tape lines. Apply the plate. Now you can slide the plate just a bit to get her perfectly straight and set that way.
When it comes time to remove the plate, you'll saw it off with fishing line, just like you do when only the tape is applied. Works like a charm and allows you to position the plate to get her straight.
Old Dec 26, 2008 | 12:36 PM
HG's Avatar
HG
Ok, thanks to all. I'll wait for some warmer weather to return. That may be March.
Old Dec 26, 2008 | 12:38 PM
rws.1's Avatar
rws.1
Wrong.
Old Dec 26, 2008 | 01:07 PM
HG's Avatar
HG
Just went out to be sure the plate fit. I'm confused, I was under the impression there was a plate between the pipes. There is none, does it attach to the fiberglass which looks to be the liner in the trunk area. First C5 so it's all new to me.
Old Dec 26, 2008 | 01:18 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Yes.
And the supplied tape will hold the plate on very firmly.
Old Dec 26, 2008 | 01:28 PM
HG's Avatar
HG
Got it Now I'll wait for warmer weather
Old Dec 26, 2008 | 02:27 PM
jrose7004's Avatar
jrose7004
Clean the area where you attach with denatured alcohol!
Old Dec 26, 2008 | 02:30 PM
Bell's Avatar
Bell
Yes, it applies to the plastic trunk well. There is no plate between the exhaust tips unless you have a Magnaflow cat back (the only one like that I know of). You must clean the area super super duper clean. After cleaning with whatever you normally use to wash the car, be sure to clean it again with alcohol (I just use regular isopropyl alcohol and it works fine). If you don't want to wait for warm weather, use a hair dryer or heat gun to warm up both the surface AND the adhesive on the tape. Be very careful with placement because once it touches, you won't be able to pull it back off without a great deal of aggravation. I know if feels heavy, but the tape will hold just fine. Mine's been on my daily driver now for about two years and 30,000 miles, many potholes and terrible roads. I used to worry about it falling off, but not anymore. I think a towtruck could pull the car by it if they could just figure out how to hook up to it. Good luck and post your results with application.
Old Dec 26, 2008 | 02:38 PM
HG's Avatar
HG
Actually, it's fairly warm today compared to earlier in the week when the wind chill was 0. It's 34 degrees now. Thanks
Old Dec 27, 2008 | 01:03 AM
waddisme's Avatar
waddisme
There is a vendor here who sells a led light kit for like $35 that will light the plate up when you have your lights on. Pretty and easy to install. Look for it.
Old Dec 27, 2008 | 01:06 AM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Old Dec 27, 2008 | 09:22 PM
The rear exhaust plate I had was mounted using double sided tape and was on the car for 6 years before I sold the vehicle - and it showed no signs of coming off anytime soon. Just be sure to clean the mounting area really well.
Old Dec 27, 2008 | 09:23 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
No! The tape holds fine and for a very long time - use "NO" bolts at all
Thanks,Matt
To Corvette Exhaust Plate
