Born on date
Does anyone know if this is the date the car came off the line? I wouldn't think it has anything to do with the date the part was made.
Thanks.
Your friendly local GM service writer can do it as well.
This site might give you some reference...
http://www.c5registry.com/MembersOnlly/production.htm
My thoughts exactly Thanks,Matt
x3
As for the C5 Registry website, note the disclaimer at the top of the first page for each model year that states: "Numbers Reflect Start Of Production Day". This information came from and was originally posted (but no longer) at the assembly plant's website, http://www.bowlinggreenassemblyplant.com/. The assembly plant website used the following disclaimer for the info they posted: "Vehicle Identification Numbers are taken at the start of General Assembly Trim Department." Thus, the information that you're looking at really only shows the VINs that started through the Trim Department that day, not the ones that actually came off the assembly line or had that day as their build day. (The definition of build date that I've most often seen is the date that the car was first started and was able to run/move under it's own power.) Although many people here may find their car's actual build day to be one or two production days after the date shown at the C5 Registry site, I've seen some build dates that were two weeks or more after the date shown, especially when this date was just prior to the start of a vacation break.
However, as mentioned by several above, one can determine their car's actual build date from the Build Information portion of the GM Vehicle Inquiry System (VIS).
For the Corvette enthusiast, the build sheet may be a very nice piece of documentation to have. However, the build sheet will NOT tell you the build date for the car. Keep in mind, the build sheet is produced sometime prior to the build start and accompanies the car down the assembly line as it is being built. There is a machine printed date and time at the very top right of the build sheet and this is the only printed date and time that appears on the build sheet. I asked Adam Boca, the NCM Events and Vendor Coordinator, some time ago if he knew or could find out about the significance of this printed date and time. Adam's reply was that it is the projected production date and not the car's actual build date. Most people will find this printed date to be a number of days prior to their car's actual build day. In the case of our car, the printed date on its build sheet is 13 days prior to the car's build date.
Too, reproduction copies of the build sheet can be ordered from the NCM - much easier than taking the car apart:
Order Forum
Order Forum
To answer the question, What is the significance of the build date? Some of us just want to know. Simple as that.
I was surprised at all the things that had to be fixed because it's been about 40k mi of basically trouble free motoring for me.
If you bought yours used, you might find it useful to see the repair history.
I won't disclose who did it for me as I don't want him to be flooded with requests, but his name appears in this thread in a post from another member.
"who peed in your Post Toasties"??......that's a good one.
Do they even make those any more?
