how difficult is it to remove the emblem on a corvette and what is involved in the process? i know typically you can use a hair dryer but i wasn't sure if doing that would have any adverse effects on the composite material the body panels are made of.
thanks
warmed mine up with blow dryer then used fishing line,6lb test and sort of sawed at it after about half way it will just pull off slowly.used finger to rub off excess glue took only about 10 min.Then polished looks great,cant decide if I want to put it back on or not.
thanks for the replies, i was hoping it would be that easy. the previous owner put acrylic corvette lettering on the rear fascia as well as additional flag emblems on the sail panel (i think that is what its called); that is what i am hoping to get off. i wanted to make sure i could remove them safely and relatively easily before i purchase the vehicle.
