Vin check
If it's for a CARFAX, expect to have this request locked by a moderator.
I think there are after market simulators available if you chose to remove the F45 shocks.
VEHICLE INFORMATION
Merchandising Model : 1YY07 Warranty Start Date : 03/22/1999
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : WALTER EARL CHEVROLET, INC.
PO BOX 609
BRIDGEWATER , MA 02324-0609
(508) 697-6000
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
09/27/2006 109628 # V1409 - 04006 - INSTALL WIRE KIT ONLY - U.S. MANUALS 41539 miles
08/14/2002 069746 # C1061 - FRONT SIDE DOOR WEATHERSTRIP REPLACEMENT - LEFT SIDE 23810 miles
08/14/2002 069746 # C0101 - GLASS, FRONT DOOR - LEFT - ALIGN 23810 miles
08/14/2002 069746 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 23810 miles
05/22/2002 066962 # C6871 - DRIVER SEAT CUSHION COVER REPLACEMENT 19558 miles
05/22/2002 066962 # C7051 - COVER AND/OR PAD, FRONT SEAT BACK CUSHION - LEFT - R&R OR 19558 miles
05/22/2002 066962 # J5670 - MASS AIRFLOW SENSOR REPLACEMENT 19558 miles
10/11/2001 078707 # C6711 - HINGE ASSEMBLY, SEAT CUSHION FRAME - DRIVER - REPLACE 19418 miles
10/11/2001 078707 # J0667 - BELT, PRIMARY ACCESSORY DRIVE - REPLACE 19418 miles
10/11/2001 078707 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 19418 miles
10/11/2001 078707 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 19418 miles
05/15/2001 073944 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 16694 miles
05/15/2001 073944 # N2871 - STEERING/SUSPENSION/RIDE CONTROL RELAY REPLACEMENT 16694 miles
05/07/2001 073670 # B2308 - HATCH ROOF ASSEMBLY - ONE PIECE - REPLACE 16533 miles
05/07/2001 073670 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 16533 miles
03/15/2001 071911 # E4160 - STABILIZER SHAFT REPLACEMENT 15527 miles
03/15/2001 071911 # C3348 - FRONT SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 15527 miles
03/15/2001 071911 # C8835 - STEERING WHEEL INFLATABLE RESTRAINT MODULE REPLACEMENT 15527 miles
03/15/2001 071911 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 15527 miles
03/05/2001 071627 # B2317 - STRIKER, HATCH ROOF - LEFT - REPLACE 15365 miles
03/05/2001 071627 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 15365 miles
03/05/2001 071627 # E2147 - STABILIZER SHAFT LINK REPLACEMENT - BOTH SIDES 15365 miles
03/05/2001 071627 # N9995 - CUSTOMER CONCERN NOT DUPLICATED 15365 miles
12/05/2000 069043 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 14072 miles
10/31/2000 052130 # B2316 - STRIKER, HATCH ROOF - RIGHT - REPLACE 13337 miles
10/31/2000 052130 # B2317 - STRIKER, HATCH ROOF - LEFT - REPLACE 13337 miles
07/26/2000 064261 # K5392 - LINES AND/OR FITTINGS, TRANSMISSION OIL COOLER - LOWER - A 11178 miles
06/30/2000 048889 # C2000 - WINDSHIELD GARNISH MOLDING REPLACEMENT - RIGHT SIDE 10312 miles
06/13/2000 062963 # C0182 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - RIGHT SIDE 9000 miles
06/13/2000 062963 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 9000 miles
03/28/2000 060304 # B2316 - STRIKER, HATCH ROOF - RIGHT - REPLACE 8342 miles
06/07/1999 038696 # C3157 - BODY LOCK PILLAR UPPER TRIM PANEL REPLACEMENT - RIGHT SIDE 2380 miles
06/07/1999 038696 # C3360 - PLATE AND/OR INSERT, FRONT DOOR SILL - RIGHT - REPLACE 2380 miles
06/07/1999 038696 # C3002 - TRIM, ROOF CENTER SUPPORT - CENTER - R&R OR REPLACE 2380 miles
06/03/1999 038618 # C1420 - WEATHERSTRIP, HATCH OR FRONT ROOF PANEL - RIGHT - REPLACE 2166 miles
06/02/1999 038589 # C0220 - GUIDE, FRONT DOOR WINDOW - RIGHT - R&R OR REPLACE 2085 miles
06/02/1999 038589 # C4201 - FRONT FLOOR PANEL CARPET REPLACEMENT - LEFT SIDE 2085 miles
06/02/1999 038589 # B4001 - FRONT SIDE DOOR ADJUSTMENT - LEFT SIDE 2085 miles
05/19/1999 038237 # C0100 - GLASS, FRONT DOOR - RIGHT - ALIGN 1725 miles
12/03/1998 A14074 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1694 kg (3735 lb) Order Number : 308GQH
Build Date : 12/02/1998 Build Plant : 1X5Y - BOWLING GREEN
OPTION CODES
AG2 AK5
AQ9 BGR
B34 CF7
CJ2 DL5
DL8 D42
FE1 F45
G90 G92
IL3 JL4
JL9 K63
LS1 MX0
M30 NB6
NC7 NG1
NK4 QD4
R9U R9Z
T96 UN0
UV7 UZ6
U52 VL7
V49 V73
XGG YGH
1AZ 1SA
67I 673
70U
All 1999 Model Corvettes come up with codes only, click HERE for a description of option codes. Hope this helps you out.
