got z06 shocks
Old Dec 29, 2008 | 02:28 AM
ferrari red vette's Avatar
ferrari red vette
Default got z06 shocks
ditched the F45 shocks from my 1998 vert..
replaced with 2003 Z06 shocks
car actually rides smoother, and at the same time is more responsive and handles better. all my other suspension parts are stock (ie: leaf springs, etc)
one question.. my front now sits about 3/4 inch higher than before. the rear is the same exact as before. any ideas why? only thing i can think about is that the old shocks were bad (when you compress them by hand, they dont pop back up) so it was sitting lower before due to bad shocks.. but if that is the case, why isnt the same true for the rears (why isnt the rear sitting higher now)?
any advice is appreciated, thanks!
Old Dec 29, 2008 | 04:14 AM
Davinss's Avatar
Davinss
It may take a week for the suspension to settle.
Old Dec 29, 2008 | 06:10 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Did you install yourself and if so how much pain was it? I am thinking of doin this ,got 61K on the clock????
Old Dec 29, 2008 | 07:33 AM
Let the suspension settle a bit and then see where it is.
Old Dec 29, 2008 | 09:59 AM
gpotski's Avatar
gpotski
Pretty easy install...I followed the following link and did 2004 C5 Z06 shocks last year...
http://fuzzydiceracing.com/test.htm
Old Dec 29, 2008 | 10:02 AM
Purerock105's Avatar
Purerock105
I have a set of C6/Z06 shocks and am looking to replace my F45's as well. Did you delete the F45 from the computer or do the resistor set-up...?
Old Dec 29, 2008 | 10:07 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
but its more of how much time the car is driven.
ecoman's Avatar
ecoman
I have the f45 also and will be putting in bilstein sports i picked up here on the forum going to try the resistor trick hope to do in the next week.
You should swap out the sway bars also.
Old Dec 29, 2008 | 10:42 AM
BigSexy181971's Avatar
BigSexy181971
The front shocks usually take a lot more abuse then the rears, this holds true for brake pads and any other front components. Your fronts were definitely shot if they did not rebound back up. Mine were the same way when I replaced all four of mine. What a difference in ride. Did you push the rears down the same as the front? Did they also not come back out?
They are very easy to change. A trick though is to wire the shocks after you compress them a little. That will make them much easier to fit into place and bolt up. There are only 3-4 bolts/nuts per shock. Very simple. If you can change a tire you can change your own shocks. Good Luck... Rob
Old Dec 29, 2008 | 08:27 PM
ferrari red vette
i had a shop do the work, but it was pretty easy
i just got back from a 600 mile trip.. and the car still sits the same. im 100% sure it wont settle, since the shocks i purchased already had 10k on them
for the F45 delete, i did the resistor method.
Old Dec 29, 2008 | 09:36 PM
bencini231's Avatar
bencini231
I would think it would have settled by now.
Old Dec 29, 2008 | 09:39 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
I put Z06 shocks and sway bars on my '98 a few years ago. If I remember correctly, it took a couple of days to settle, but after 600 miles it should have settled by now.
If not, lower that sucker!
Old Dec 29, 2008 | 09:50 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
After 600 miles time to take action lower it
Old Dec 29, 2008 | 10:23 PM
Ryan L's Avatar
Ryan L
Buy the Zip Products lowering kit bolts and be done with it.
Old Dec 31, 2008 | 04:10 PM
ferrari red vette
the car is already lowered to the max on the stock bolts...
doesnt make sense, because before putting in the Z06 shocks it was low.. now its not. i was told the z06 shocks lower it further, guess not.
Old Jan 6, 2009 | 03:30 AM
ferrari red vette
up...
To got z06 shocks
