[Z06] Comming Up Mods
Old Dec 30, 2008 | 03:06 PM
slverbulletz06's Avatar
slverbulletz06
Default Comming Up Mods
04' Zo6 with about 80k Miles on it i am saving up for a G5X3 Cam Package (LSA 114), Smaller Pulley, and Fast Intake 92mm and throttle body, i already have LT's and Vararam Cold Air. Does anyone have advice or useful information?? Its also a daily driver.
Old Dec 30, 2008 | 03:56 PM
SCBQQSTN's Avatar
SCBQQSTN
X3 is pretty big for a DD, maybe you should consider X1. other then that enjoy the new power!
Old Dec 30, 2008 | 04:54 PM
FourG63 97GST's Avatar
FourG63 97GST
one thing I regret doing when I did my X3, I pulled the heads to do lifters also, I regrets not getting the heads atleast ported.
It can be daily driven, imo its right on the edge, what makes or break the car's is drivibility is when you a big cam combined it with an grabby clutch.
If I had the money i'll go little smaller on the cam, like a X1 or X2, an nice set of heads combined with the fast.
Old Dec 30, 2008 | 06:04 PM
slverbulletz06
Ok so do you think i should go with a X2 instead?? im not going to do my heads
Old Dec 30, 2008 | 06:31 PM
golfinz's Avatar
golfinz
Define your power goals then you can pick your cam. I would pick your heads first then tailor your cam to that, and not the other way around (I think this is a mistake that many/most, including myself, make)
Old Dec 30, 2008 | 06:56 PM
chevyvettezr1's Avatar
chevyvettezr1
I just had an g5x4 cam installed by LGM. I very pleased with my cam, its a little extensive for a daily driver(its a weekend warrior though). But it pulls like a raped ape from 2900 rpm all the way to redline. I highly recommend LG's work, and customer service is top knotch.
Old Dec 31, 2008 | 09:35 AM
slverbulletz06
Well im just lookin to pick up some more power but not to much to have to do heads, everyone tells me that the Zo6 heads are the best flowing heads that you can have with a pretty good cam, and Lgm are the guys i have decided to let do my work!!!
Old Dec 31, 2008 | 11:41 AM
golfinz's Avatar
golfinz
K, so if you aren't doing heads, what do you want to make power wise. The difference between making 415rwhp and possibly 430rwhp is a huge jump in cams
Old Dec 31, 2008 | 11:52 AM
SCBQQSTN's Avatar
SCBQQSTN
i heard that a set of 205 AFR heads will net 30+ rwhp over LS6 heads
Old Dec 31, 2008 | 12:35 PM
sublime1996525's Avatar
sublime1996525
One thing you're going to have to consider is putting new valve springs on. I'm sure I've read somewhere that the ls6 springs are good to a .575" lift or somewhere around that.
Old Dec 31, 2008 | 03:33 PM
slverbulletz06
well the package comes with new valve springs, I believe. i want about 430 to the wheels and the afr heads aint in my budget yet so im not doing those and i know they give you a whole crap load of power but i have to wait
Old Dec 31, 2008 | 04:20 PM
ctusser's Avatar
ctusser
No, G5X1 for a daily driver. The G5X2 isn't much tamer than the X3 for drivability.
Old Dec 31, 2008 | 04:27 PM
slverbulletz06
whats the stock Cam in a 04 Zo6
Old Dec 31, 2008 | 04:41 PM
ctusser's Avatar
ctusser
Stock cam specs:
.551/.547 lift, 204/218 duration, 117.5 LSA
G5X1 specs:
.588/.574 lift, 228/232 duration, 112 or 114LSA
G5X2 specs:
.595/.608 lift, 232/240 duration, 112 or 114LSA
Old Dec 31, 2008 | 04:58 PM
slverbulletz06
So maybe i should just do the X1
Old Dec 31, 2008 | 08:05 PM
ctusser's Avatar
ctusser
If the car is cammed and you are talking about stock LS6 heads. A properly ported, shaved, and valve jobed set of LS6 heads will be within 5 hp of the AFR heads for nearly half the price.
Old Jan 1, 2009 | 03:31 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
I haven't see any "budget" LS6 head on the same level as AFR. Something in the 228-232 range will be a lot better for a daily driver.
Seth
To Comming Up Mods
Old Jan 1, 2009 | 04:43 PM
ctusser's Avatar
ctusser
Seth
No doubt the AFR's will be a bit superior to budget heads, so in some sense you get what you pay for. There are also more expensive LS6 heads that have been proven to be on par with the aftermarket offerings but many of them are not cheap either. I guess it all depends on how much more the end user wants to pay for those extra few HP
Just went to your website and looks like you have a nice market niche.
Since you sell Patriot, AFR and Trickflow perhaps you could enlighten us by posting an impartial dyno comparison with the same engine b/t the Patriot heads and it's comparable aftermarket alternative.
Old Jan 2, 2009 | 05:02 PM
1slowride's Avatar
1slowride
Default Cam
Sorry, wrong info.
Old Jan 2, 2009 | 05:05 PM
C5Z's Avatar
C5Z
Originally Posted by Voodoo Z
I disagree with the X3 cam being tooo big for a dailey driver.
I have a Comp Cam 226/228 .585/.590 114 LSA = Almost same as VRX3
With
longtubes
Honker CAI
Underdrive and a tune
= 420 hp & 385 tq
Car does cut up at idle, and clears right up and runs smooth when driving.
You're talking about a different cam. The one he is referring to is an LG cam, not a VR cam. The G5X3 is in the 240's duration and is very large for a daily driver.
