[Z06] Any one running this cam
Old Dec 31, 2008 | 10:27 AM
ctheusa's Avatar
ctheusa
Default Any one running this cam
Was wondering if any one is running a MTI stealth 2 cam in their Z06?
If so what kind of numbers did you gain and do you like it.
Steve
Old Jan 2, 2009 | 04:07 PM
C5Z's Avatar
C5Z
I'm not a fan of reverse split cams for the LS6. A reverse split was not a bad idea on a stock LS1 b/c it didn't have as good intake flow with the old manifold and LS1 heads. Even with stock LS6 heads, just get your throttle body ported and it will flow well enough. Get an even cam or slight forward split in the low to mid 220's duration and it will be plenty streetable and make more power than the Stealth II.
For all the hassle involved in a swap and tuning you might as well do it right the first time.
Old Jan 5, 2009 | 10:14 AM
ctheusa's Avatar
ctheusa
thanks
To Any one running this cam
