[Z06] Oil pressure question
Old Jan 1, 2009 | 09:10 PM
David426's Avatar
David426
Default Oil pressure question
My oil pressure reads 39lbs at idle and up to 80psi at 4800rpm.. This is on my 02 z06 44k miles.. I know about the crappy sending units.. I had one replaced at 40k on my 99 c5.. Usually when they go out they peg 80psi and on the DIC pressure reads even higher.. like around 130psi.. Any suggestions... I just had a mobil 1 5w-30 oil change with a mobil 1 oil filter
Old Jan 2, 2009 | 09:30 AM
David426's Avatar
David426
any answers
Old Jan 2, 2009 | 11:21 AM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Cold or warm readings? Big difference.
Old Jan 2, 2009 | 11:25 AM
ptindall's Avatar
ptindall
Doesn't sound like the sensor. I don't what know it is though. What does the DIC read when the gauge reads 80psi? 80psi or more?
Old Jan 2, 2009 | 11:48 AM
CHJ In Virginia's Avatar
CHJ In Virginia
That is about the pressures I show when the oil is cold < 100 Deg. When the car gets up to normal operating temp - oil > 150 Deg, I show about 28 PSI at Idle and 45 or so at 4000 RPM. If that reading is fully warmed up then I say you have a sender problem or one that is about to go south.
Old Jan 2, 2009 | 12:08 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
28-32 psi at idle when the oil is at 210 degrees. 38-42 at 4000rpm when at 210 degrees.
Old Jan 2, 2009 | 12:57 PM
David426's Avatar
David426
the readings on my gauge match the dic number... Oil temp is not an issue 40psi at idle and 75-80 under wot this is at any temp
To Oil pressure question
