[Z06] How to fix shift boot from........
Old Jan 4, 2009 | 04:22 PM
stock z06's Avatar
stock z06
Default How to fix shift boot from........
scooting down the shifter and not staying up close to the ****?
any quick fixes? glue? double sided tape?
ed 2002 z06
Old Jan 4, 2009 | 04:57 PM
twoboysinheritance's Avatar
twoboysinheritance
Default a little dab will do ya
I had the same problem and just put a small amout of Gorilla Glue on the lock nut (I ground the nut round first so the boot covered it looked better too) and it worked perfectly
Old Jan 4, 2009 | 05:20 PM
Higgs Boson's Avatar
Higgs Boson
I installed a C6Z shifter and **** and the stock boot doesn't fit around the new ****. I cut the factory ring out of the boot (at the top) and turned it inside out, strapped a zip tie around it at the **** and folded it back down and clicked it in. Looks good, fits around the wider **** and stays put. Might help...
Old Jan 4, 2009 | 05:22 PM
hotwheels57's Avatar
hotwheels57
You don't need zip ties, tape or glue to hold it up tight to the ****.
Find the appropriate sized (ID to the lever) rubber grommet at the local hardware store. You might even already have one in your garage/shop.
The friction is enough to hold it up there. And it's easily removed...
Old Jan 5, 2009 | 12:41 AM
TheDVS1's Avatar
TheDVS1
I used a dab of clear silicone conservatively applied to the Hurst 8-ball shift **** locknut, and slid the boot up over the nut and let it dry overnight. It's solid as a rock now, and can be removed as necessary in the future since the silicon remains relatively pliable.
Old Jan 5, 2009 | 01:05 AM
cdn ws6's Avatar
cdn ws6
when I installed my C6Z purchased from stol3n, he informed that I would need a rubber o-ring from the hardware store as was already stated. Works great! I think it was a # 14 or #15
To How to fix shift boot from........
