Difference between FE3 and Z51?
Old Jan 4, 2009 | 06:25 PM
TDLW's Avatar
TDLW
Default Difference between FE3 and Z51?
Is the option FE3 and Z51 the same thing? If so, what does that mean/include on a 97-2000?
Old Jan 4, 2009 | 07:34 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
No they are not the same. The base model has the FE-3 suspension,
you could order the option Z-51 suspension.
Old Jan 4, 2009 | 07:41 PM
Torchblue's Avatar
Torchblue
Base suspension is FE1. Z51 is included with FE3. I think they are the same. ZO6 has FE4 suspension.
Old Jan 4, 2009 | 07:42 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I beg to differ - the base suspension RPO is FE1, the FE3 suspension is a part of the Z51 package, which includes larger diameter sway bars, higher rate springs, stiffer shocks, and a power steering cooler. The Z51 package also required the G92 performance axle ratio (3.15) if the car was to be equipped with the A4 automatic.
The FE1 package is a part of the F45 Selective Real Time Dampening and the F55 Magnetic Ride suspension. The difference between these options and the FE1 is the shocks.
For reference purposes, the FE4 suspension is the Z06.
Old Jan 4, 2009 | 08:10 PM
TDLW's Avatar
TDLW
Soooo, does FE3 equate to Z51 in manual transmission equipped cars?
Thanks!
Old Jan 4, 2009 | 09:08 PM
blacksedan87
Thanks!
Yes - it will say both FE3 and Z51 on your RPO sticker. If you have a '97 or a '98. it's on the bottom on the driver's side rear compartment cover. If it's a newer model, it will be on the inside of the glove box door. It is alphabetical.....
Old Jan 5, 2009 | 12:02 AM
GrayC5's Avatar
GrayC5
Once again, Randy is spot on.
RPO Z51 is the Performance Handling Package which is made up of the RPO FE3 Sport Suspension and a power steering cooler.
Old Jan 5, 2009 | 11:37 AM
El Zappo's Avatar
El Zappo
From: Remember the average response time to a 911 call is over 6 minutes. The average response time of a .357 magnum is 1400 fps.
As an added note:
FE3 is the RPO Code the Factory Production line employees used when the C5 was built with the Z51 Package.
Old Jan 5, 2009 | 07:44 PM
GrayC5's Avatar
GrayC5
Originally Posted by El Zappo
As an added note:
Again, FE3 is the RPO code for the Sport Suspension. Z51 also is an RPO code and it is the RPO code for the Preformance Handling Package. The Z51 Performance Handling Package consists of the FE3 Sport Suspension plus a power steering cooler: FE3 + power steering cooler = Z51. See following link:
Chevrolet Corvette C5 RPO Code List
We ordered our car from the factory with the Z51 Performance Handling Package. Z51 is the RPO code that was entered on our copies of both the Order Form and the Vehicle Order Detail form that we received back. FE3 does not appear on either of these order forms. However, both RPO codes, Z51 and FE3 do appear on our car's factory build sheet.
Hope this helps to clarify.
Old Jan 5, 2009 | 08:16 PM
road pilot's Avatar
road pilot
Sorry I'm so stupid. This question has come up before and for
some reason I keep getting FE-1 and FE-3 mixed up.
I had a FE-1 and converted to FE-3 on my Y2K and I haven't
been the same since.
Old Jan 5, 2009 | 09:24 PM
blacksedan87
You're not stupid - it can be confusing.....that's why we're here, to cut through the confusion!
To Difference between FE3 and Z51?
