How big can i go?
Old Jan 4, 2009 | 11:24 PM
Evers98's Avatar
Evers98
Default How big can i go?
looking to take my stock ls1 out of my 98 c5 that has 127000 miles and rebuild it. looking to see how big of a C.I.D i can go with my stock block?
Old Jan 5, 2009 | 12:23 AM
Evers98's Avatar
Evers98
Old Jan 5, 2009 | 12:32 AM
happa's Avatar
happa
Are you asking Cubic Inches? if so my opinion is
I beleive a 383 will do good and a 402 will be pushing a little with a stock block.
Old Jan 5, 2009 | 12:34 AM
Evers98's Avatar
Evers98
yeah looking for Cubic Inches of Displacement for a stock ls1 how big can i go?
Old Jan 5, 2009 | 12:46 AM
happa's Avatar
happa
383 will do good and a 402 will be pushing a little with a stock block. Good Luck!
Old Jan 5, 2009 | 12:47 AM
Evers98's Avatar
Evers98
Thanks.. anybody used a stock block before? or is it just better to get a block already done the size i want?
Old Jan 5, 2009 | 01:14 PM
Evers98's Avatar
Evers98
bump
Old Jan 5, 2009 | 08:01 PM
Evers98's Avatar
Evers98
Old Jan 5, 2009 | 10:10 PM
MPM IV's Avatar
MPM IV
How big do you want to go? You can't bore these blocks much so you're pretty much limited to 383, unless you re sleeve the block. Seems most go with the ls2 or ls7 block if they want bigger though.
Old Jan 5, 2009 | 10:45 PM
itzza427's Avatar
itzza427
You might want to get a hold of the October 08 Car Craft Magazine,,They have a cover story on Gen III stroker motors. gives you a lot of info on the stock motors bore and strokes and many options and combinations available,and pros and cons of various combos.One of the cons is piston skirt scuffing when the stroke pulls the skirt too low in the bore!!Worth looking up,,good inf that might save some headaches in the future!!
Old Jan 5, 2009 | 11:26 PM
MattF G419's Avatar
MattF G419
A friend of mine has a 409ci out of a stock C5 block, but I wouldn't recommend it. The car needed a ton of extra cooling stuff to stay cool and ended up being more trouble than it was worth, whereas a 402 would have been basically the same thing without the headaches.
Old Jan 6, 2009 | 12:48 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Do it right the first time. Get the correct block and forge it incase you want to bump up the power in the future. It is lot more money but very well worth it!
Old Jan 7, 2009 | 12:03 AM
Evers98's Avatar
Evers98
thanks all still open for info
Old Jan 7, 2009 | 08:54 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
If you want to get some good advice it would be helpful to know a little bit more about what your goals are for the car.
There are lots of ways to make big power. Problem is you can't use it on the street because of traction issues. You also have the legal issues to consider.
If you bump up the power significantly you will need to also make improvements to your drivetrain such as new clutch, better torque tube, tranny, and differential. It adds up real fast! And when you go to sell you won't get much of what you spent back.
It's my understanding that the earlier LS1 blocks are not as good as the later blocks, which is something you should consider.
To How big can i go?
