C3 to C5
Old Jan 7, 2009 | 08:51 AM
silver74vette's Avatar
silver74vette
Default C3 to C5
Greetings all, I have played mostly in the C3 area but have moved on from my 74 to a 50th anniversary convertable.
I searched the threads and found info on idle speed for modded engines but not for stock.
My engine idles about 850 rpm and when I shut it down it spins down longer than I am used to and has some valve noise.
I would appreciate some input on if this is normal or not and what some of the stock engines idle at.
Thanks in advance, Chris
Old Jan 7, 2009 | 10:26 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
850 RPM's at idle is about right for a stock C5. When you shut down the C5 a little stumble is normal. Not what you are used to in the older car. If you are talking about valve noise when cold it is also normal and probably a little piston slap. As long as it goes away when warmed up you're OK.
Old Jan 7, 2009 | 12:25 PM
silver74vette
Thanks for the info, I appreciate the reassurance.
Old Jan 7, 2009 | 12:53 PM
Mikvi's Avatar
Mikvi
St. Jude Donor '10
Default Been There, Done That
I'm glad you asked the questions. I went from an 82 to an 03 and had the same concerns. I love the 03, but miss the 82, it was so easy to work on. Good luck
Old Jan 7, 2009 | 04:35 PM
BlueDream's Avatar
BlueDream
Congrats on the 2003 and welcome to the C5 side of the forum.
Old Jan 7, 2009 | 04:40 PM
dougbfresh's Avatar
dougbfresh
Easier to work on, are you kidding, the 82' I had was the biggest PIA to change the plugs on I ever owned. Only had a dozen heat shields and other assorted junk around the exhaust manifolds.
Old Jan 7, 2009 | 07:59 PM
dobewillie's Avatar
dobewillie
congrats and welcome
Old Jan 7, 2009 | 08:07 PM
bencini231's Avatar
bencini231
Congrats and hope you get the info your looking for.
Old Jan 7, 2009 | 08:23 PM
lil vette's Avatar
lil vette
Mine idle's at 650RPM
Old Jan 7, 2009 | 08:28 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Welcome to the C5 fold.
Too bad you couldn't keep the C3 and have the C5. You know what they say," He who dies with the most toys............"
Old Jan 7, 2009 | 09:25 PM
IMXCITD's Avatar
IMXCITD
congrats on the new ride!!
Old Jan 7, 2009 | 09:38 PM
vett79's Avatar
vett79
Congrats! You'll enjoy the C5 but like Mikvi I miss the old '79 for the ease of maintainance and being a bit more robust in some areas. I don't think I'll go back unless I can own a '69 roadster and keep my 98.
Enjoy!
Old Jan 12, 2009 | 02:14 PM
silver74vette
Thank you all,
I had to sell the bike and the old Vette to swing the "upgrade" with the domestic chief executive. I really enjoy driving the C5 but nothing is like looking down the hood of the Stingray.
I never had much trouble working under the hood, but the dash is another matter.
Thanks for the warm welcome, Chris
Old Jan 12, 2009 | 04:30 PM
TraceZ's Avatar
TraceZ
Is your C5 a stick?
If it is, try holding in the clutch when you shut the engine off. That will get rid of the "death rattle" when the engine stops. It's a known "feature" of the C5.
Old Jan 12, 2009 | 07:27 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
congrats on your new C5 and welcome to the mod crew
Old Jan 12, 2009 | 07:42 PM
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
Thank you all,
Put the lights up and look down the hood and fenders, very similar
to the C3 I think. Welcome and have fun with the C5.
Old Jan 12, 2009 | 10:37 PM
Jet-Jock's Avatar
Jet-Jock
Originally Posted by TraceZ
Is your C5 a stick?
I was going to ask the same thing is it a MN6 model?
If so, put it in Reverse (will only go with the key in the ON position) and holding the clutch in shut it down. It should be fine.
My 6-speed idles 650 rpm with AC on which it always is ON
To C3 to C5
Old Jan 12, 2009 | 10:47 PM
KorbenDallas's Avatar
KorbenDallas
I had an '81 for about a year then bought my C5 and I've had it for 6 years now. I hated to see the C3 go, but man the C5 made up for it!
Enjoy the C5!
Old Jan 12, 2009 | 10:54 PM
versatile's Avatar
versatile
Is your C5 a stick?
You don't know how glad I am at this moment!
Old Jan 13, 2009 | 05:18 AM
Congrats on moving up to a C5. Hope you enjoy the car.
