c6 splash guaurds
Jan 7, 2009 | 11:39 PM
c6 splash guaurds
Jan 8, 2009 | 12:35 AM
i bought a set. i haven't installed them but they will require trimming modifications to fit a c5.
the trimming would be similar to what you need to do to put a set of OEM c6 z06 rear guards on a c5.
so no, they wont easily fit on a c5.
Jan 8, 2009 | 06:41 AM
Jan 8, 2009 | 11:38 AM
Quote:
Originally Posted by
hollyt
these are not what he is talking about.
Jan 8, 2009 | 11:45 AM
these are what he is talking about
Jan 8, 2009 | 12:23 PM
jdmvette
I've got a box of the same and will be putting them on my torch red C5 this winter.
Maybe someone will provide some info on installing them before I/you get to it.
Jan 9, 2009 | 11:34 PM
Thanks Jason, I figured if anyone knew, you would
Jan 10, 2009 | 05:10 PM
Premium Supporting Vendor
There is a lot of interest in this. It would be great for someone to do it and post their trials and testimonials.
Jan 10, 2009 | 05:33 PM
Gene Culley
Gene
are the rears as wide as the Z06's?
Feb 16, 2009 | 07:56 PM
No one used this on the C5 yet? :/
Feb 16, 2009 | 08:34 PM
Feb 16, 2009 | 10:21 PM
Looks sweet!
Was it painful? Do you have a writeup of the stuff you had to do to get it to fit your C5?
-Boomie
Feb 16, 2009 | 10:40 PM
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
boomie1
Looks sweet!
-Boomie
Feb 16, 2009 | 10:54 PM
i modified a set of those for my own specific purposes. i used the front set of the guards for the front of my rear tires:
install was about the same as installing c6 z06 rear guards, a lot of hand shaving and trimming required.
if you were to try to install them as they were intended on a c5, they will still require a lot of hand shaving and trimming.
Feb 16, 2009 | 11:31 PM
I installed the C6Z06 splash guards on my C5....I used a dremel with a sanding wheel to trim the splash guard to fit the contour of the car. Just takes time....
Feb 17, 2009 | 09:01 AM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Feb 17, 2009 | 01:26 PM
Jhonathan_W
Thanks Jonathan, but those are the Z06 guards. This thread is about the C6 guards - p/n 19170234
-Boomie1
Feb 17, 2009 | 09:47 PM
Jhonathan_W
That is the set of instructions I used.
boomie1
-Boomie1
I honestly don't know the difference between the "regular" C6 gaurds and the C6 Z06 gaurds ... a friend of mine picked these up for me when he was getting a set for his C6. So, I believe what I have installed are the "regular" C6 gaurds if they are in fact different from the c6 Z06 gaurds (okay ... now I think I'm as confused as a pig wearing a watch) ...
Feb 17, 2009 | 10:31 PM
so the install is similar.. that helps - thanks!
So from what I understand, earlier there used to be only guards for the Z06 which fit only the rear wheels.
Part Number: Left Molding. #15818636
Part Number: Right Molding. #15818637
Then GM came out with C6 guards which are p/n 19170234 (4 pieces). The C6 guards are 1 each for the front and back
-Boomie
Feb 17, 2009 | 11:08 PM
The only nagging question, yet to be answered, are the Z06's wider than the stock c6's?
