$6.49 RP 5w30
Without any basis its hard to believe,& wonder why when a product is knocked to be crap & the said product is a sponsor here ,why isn't proof required by this forum site?Afterall its kind of like slander.
Really ,we all would like to know that what we're putting in our ,IMO to me ,a car of a lifetime & a fine machine rivaling exotics costing several times as much,would not be good for it?I only try to put the best in my baby,would'nt want any thing else for it.
To me the accusations here are nothing more than an opinion. Curiously, I found the opposite opinions on other sites. Some suggest that Mobil1 offers the best deal to GM therefore that is why they are chosen. Another suggests that GM is in the business of selling new cars. They do not want an oil that would over-extend the life of a vehicle. The logic being that Mobil1 is a lesser oil thereby not over extending the life of the engine and assisting auto makers in creating a buyer to buy another vehicle in 5 years.
I use both Mobil1 and RP and have about the same amount of faith in either.
I've seen it for many years now, that Royal Purple thins out quite rapidly, going from a 5w30 to a 5w20 in just a few thousand miles (typically about 2000 miles) When I was saying this, a rep from Royal Purple decided that he would send me a free case of oil if I would agree to run their oil in my wife's Honda and get a used oil analysis done. That was a big mistake on their part, as the oil did indeed thin out quite rapidly, and the engine wear numbers were quite a bit higher than any of the other oils I have run in my wife's car. To put it mildly, I was not impressed at all with the performance of Royal Purple, it performed even worse than I expected. I'm getting much better engine wear numbers from Castrol GTX in my wife's Honda than I did with Royal Purple!
"The 4-Ball Wear Test is a good indication of the wear protection provided by an oil under severe conditions. The smaller the wear scar, the better the protection."
The Dyno test shown here is different, but is worth the read as well. Any test I've ever reviewed (except the one mentioned earlier) showed RP inferior to Mobil 1 and Amsoil.
http://www.performancemotoroil.com/Dyno_test.html
http://www.enhancedsyntheticoil.com/..._vs_AMSOIL.htm
Rossi
this is common knowledge in racing circles
Rossi
Is " Bob the oil guy" a Petro-chemical engineer?What equipment does he use for his analysis?I don't know if he is the supreme authority on oil or not,but would like some info,on him,I'll investigate.
I used al kinds of motor oils ,RP,M1,Penzoil Platinum,QS Horsepower ,all inclusive,unlike Patman,could'nt tell the miniscule performance differences between them.RP seems to run just as smooth as the others.Of course its not a Honda with 120Hp ,I 'm basing my compairison on but a C5 with a little more ponies.I don't know,I don't do oil analysis on DD cars ,or my C5 every time I change the oil,so who am I to say?Castrol GTX for you Patman,OK,but for my cars its going to be one that meets GM4718M.
IRS man told us so,please don't audit me now!
"Royal Purple uses a different chemistry than most oil producers. They are one of only a handful of marketers using Molybdenum Disulfide (Moly) in their oil formulations.....Some additive chemicals such as Moly may cause adverse conditions when used for long periods. Moly is a processed mineral that is similar in appearance to graphite. Moly has good lubricating properties when used either by itself (in dry power form or as an additive to oil or other lubricants).
Particles of the Moly can come out of suspension and agglomerate. Over time this may actually clog or partially clog oil filters or oil lines and the remainder normally settles in the bottom of the oil pan...."
"Engineers and scientists have tried for years to use Moly in motor oils but they had been unsuccessful because they could not find a way to keep Moly in suspension. Once Moly was put into suspension it would gradually settle out. It was easy to see it come out of suspension because a black sludge would collect on the bottom of the oil containers. In engines it would settle to the bottom of the crankcase or clog oil pathways and filters.
Engineers have overcome these obstacles. They have developed a process that keeps Moly in suspension and isn't filtered out. Since that time the product has undergone extensive independent testing in labs and in the field for many years to insure that the product stands up to the rigorous needs of today's engines. With the plating action of Moly reducing friction which reduces heat, this helps keep rings free from carbon buildup, prevents blow-by, decreases emission, and extends oil life. "
http://www.bobistheoilguy.com/moly.html
PS- I didn't go to Purdue
As far as bobistheoilguy goes, it's not a person, it's a message board. The original founder of the site, Bob Winters, is a Schaeffer oil dealer and his idea was to make a site where people could compare each other's oil analysis results and discuss all different brands of oil (not just the oil he sold) He no longer owns the site, and the new owners are not in the oil industry at all. However that doesn't matter, as the knowledge on the site comes from the many members, and quite a few of them are heavily involved in the oil industry. I've been an administrator on the site since 2002.
Good,never said you did.You never gave credentials until now. I just stated some credentials of someone who did & has been in the Petro-Engineering field for 20 years.Just for the record of getting some knowlegable input. But as stated onlly on the types & appplications of wear tests,not the additives of any oils.Purdue is & was a top notch Eng. school for decades (probably better ranked 20 years ago).Or do you dispute?
If what milo says is true too, whats the worry?
In summary just use what you want, we 've seen the pro & cons.Always like other points of veiw ,this is informative & I'll digest the pro & cons, & try to make an informative decision.
I have seen others post oil analysis reports where they ran Mobil 1 first and then switched to Pennzoil Platinum and the Pennzoil showed better results. The most noticeable change people find is that Mobil 1 shows higher iron levels in their reports compared to most other oils. With Royal Purple they tend to show both higher iron (valvetrain) and higher lead (bearings) than other oils. So Mobil 1 is better than Royal Purple (most oils are better than RP actually!) but Pennzoil Platinum is better than both of them. If I wasn't running Pennzoil Platinum I'd most likely choose Amsoil as my second choice.
Cadillac CTS-V Used Oil Analysis – Mobil 1 5w30 vs AMSOIL 0w30
Used Oil Analysis Comparison: German Castrol 0w30 vs AMSOIL Series 2000 0w30
Corvette C5 Used Oil Analysis Report – AMSOIL SAE Synthetic 10w30
And for the original topic at hand, and although these are AMSOIL commissioned tests for motorcycle oils and gear lubes, I think they support PATMANs position above. RP was included in both tests and did not fair very well compared to the other lubricants in the study. You'll have to draw your own conclusions as to how well these translate to automotive oils.
AMSOIL Motorcycle Oil “White Paper” (1 MB pdf file)
AMSOIL Gear Lube “White Paper” (2 MB pdf file)
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
