Help me build a "Gentleman's C5"
Here’s my preliminary definition of a Gentleman’s C5, but I’m happy to add (or delete) based on relevant feedback, so fire away, but play nice!
Gentleman’s C5 Requirements:
- Purpose – pleasure cruising, with lots of performance but no racing
- Ride – ride quality must be as comfortable as possible and very smooth, no vibrating allowed
- Ride Height – must be at stock levels to retain drivability over rough roads and speed bumps. Lowering not allowed
- Handling – car must handle well, but not sacrifice comfort
- Interior Noise – interior must be relatively quiet. Addition of sound deadener a possibility. Massive stereo & MP3 player allowed, but must look stock. Wind noise and rattles not allowed.
- Exterior Noise levels – Exhaust note must be subdued, but noticeable, with no chance of any noise violation citation.
- Engine Performance – more power is always better, but must not sacrifice above qualities. Supercharger encouraged, but engine must not overheat. Engine must start, idle and smoothly accelerate; exactly as stock engine does.
- Transmission – auto trans only. Manuals are for real sports cars
- Tires – must be non-runflats, in order to facilitate ride comfort
- Colors – pretty much any stock colors OK, wild custom colors not allowed
- Safety – Safety is paramount. No disabling of any factory features which might increase risk of injury. Must be able to give keys to granny and she could safely drive to get groceries. Things like traction control would be left in stock configuration, so if granny accidentally mashes the go pedal, the wheels don’t break loose.
- Looks - Minor mods are OK, so long as they retain basically stock appearance. Nothing wild allowed
BTW for more power, increasing displacement is more reliable then adding FI.
Congrats on you getting your car
I don't understand why you would want to add a supercharger though if you didn't want to ever race?
Good luck
I would go with big inches versus a supercharger. I have had my car both ways. I have had 2 different SC systems on it and now have a 428. For me I much prefer the big inches to the supercharger. It is quieter (even with a quiet SC head unit) and is totally reliable. If you use a mild cam and exhaust (the Z06 exhaust works great) your car will be completely drivable and will still get good gas mileage.
You can mildly upgrade the suspension for better handling without having the car ride like a cement mixer. There are many options here.
As computer technology improves performance and optimizes shift-points, the clutch becomes a determent. I see it at the track alot...time lost when shifting.
Noise reduction - I've put in the Crazy Cowboy Insulation kit (front and rear). I've also replaced the stock tunnel plate with the coated aluminum item from Elite Engineering. The result is a tighter ride as well as reduced noise and in-cabin temperatures from the exhaust pipes. Still need to insulate the doors.
Lighting - I've replaced the stock plastic headlight assemblies with glass Cibie European Export Halogen units. While it's not an HID setup, it also doesn't come with the big price tag and there's a HUGE improvement over the stock units. Tail lights and running lights are LED bulbs. I retain the look of the stock tail lights but have the brightness and faster response of LED's.
Brakes - GM Drilled and Slotted Rotors and red powder coated calipers. Stock pads.
Exhaust - I have Borla Stingers. This is one area where I don't compromise. Corvettes should growl. Period.
Audio - Pulled out the Bose system and replaced with a Premier AM/FM/XM/CD unit. Infinity front and rear speakers, no amp.
TIres - Replaced the stock Goodyear F1's with Michelin Pilot Sport A/S ZP's. MUCH smoother and quieter ride in a stock size and I retain runflat capability (something I was REALLY grateful for on the way to last year's Cruise-In!!!
).Future Plans:
Interior - I've already ordered new seatcovers from Vette Essentials along with new seat foam. The stock leather is very low grade and this will make your interior look and feel stunning. Also I will insulate the doors, put in new weatherstripping around the doors and put LED bulbs in the dash.
Audio - I'll change over the head unit to one that includes HD radio and Bluetooth so I can have handsfree phone capability, and also add tweeters, a small subwoofer, amp and crossovers (this will be professionally installed).
Suspension - Stock shocks are shot. I'm still on the fence about what to buy new, but I'm leaning towards Bilstein HD's (not Sports). Nice combination of handling and performance. I'm also replacing all the suspension bushings...still weighing whether to go with rubber or synthetic. New tie-rod ends, new ball-joints and C5 Z06 Sway Bars w/metal end-links.
Engine - Most likely, I will order a 2004 Z06 Crate motor and massage it a bit to put out good, but not scorching horsepower. I don't know if I'll go with long tube headers or not, because long tubes are much louder than stock, but I completely recognize the performance gains that they give you.
That's the bulk of it. I want a car that's reasonably fast and very comfortable. I think this will give me what I want.
- Second skin Damplifier pro and Lux Liner open cell acustic foam.
Lighting (exterior):
- "radioflyer" LED Halo tail lights
- 194 LED red rear marker lights
- Corvette enhancements tag lights
- Custom pop up projector headlights
(he he he)- HID kit for foglights (match headlights for driving lights or 3000K for genuine fog lights)
Lighting interior:
- complete LED swap (everything white)
Audio:
- Head unit (up to your preference)
- Component front speakers with a-pillar mounted tweeters (flush mounted in the corners for OEM appearance)
- Sealthbox mounted subwoofer
- Amplifier(s) mounted behind seats
Suspension:
- Z06 swaybars
- Shocks are up to your ride preference
Performance:
- Custom CAI with centrifugal supercharger with supporting performance mods (keep stock hood)
- Long tube headers
- High flow cats
- Zo6 exhaust
- Drilled/slotted rotors
- HPS brake pads
- Stainless brake lines
Appearance:
- C6Z wheels
