[Z06] back wheel hop
Old Jan 11, 2009 | 08:48 PM
last run's Avatar
last run
Default back wheel hop
hello yes i have a 2002 zo6 with 3000 miles on it and im getting back wheel hop really bad in first gear.i had a 2003 zo6 with 6000 miles on it in 2004 thru 2006 and i never had this problem running the same tires and same 30psi in the tires ,has anybody else had or have this problem
Old Jan 11, 2009 | 09:47 PM
vsocks1's Avatar
vsocks1
Street tires and "old rubber" will contribute to this problem.
Old Jan 11, 2009 | 09:52 PM
last run's Avatar
last run
ya i thought it might be these 6 year old tires that look brand new
Old Jan 11, 2009 | 10:18 PM
corvette8189's Avatar
corvette8189
mine wheel hops bad too. when i gas it hard, it just hops. i wish it would just spin the tires but no
Old Jan 11, 2009 | 10:44 PM
JGOAT's Avatar
JGOAT
i put 07 z06 shocks on mine and it helped alot
Old Jan 11, 2009 | 10:53 PM
tvlance's Avatar
tvlance
Cold weather seems to have an effect as well, or so I've noticed. Tho with you being in Florida, that may not be the case unless you've had cooler weather recently. It seems like for me that if it's below 50 degrees out that I can get wheel hop. It also depends on the condition and age of tires and pavement. I have PS2's that are 15 months old. And I've heard switching shocks helps some people.
Old Jan 11, 2009 | 11:39 PM
bencini231's Avatar
bencini231
Old Jan 12, 2009 | 09:27 PM
Goody's Avatar
Goody
LG Coilovers cured my wheel hop issues. Chevy should change the name from Corvette to Thumper.
Old Jan 12, 2009 | 09:38 PM
last run's Avatar
last run
good one !
Old Jan 12, 2009 | 10:53 PM
NeoZ06's Avatar
NeoZ06
i floor mine hard on 1st gear and they just spin...
check those tires!
Old Jan 13, 2009 | 05:54 AM
Atok's Avatar
Atok
My '03 does it also. I've heard GM re-valved the rear shocks on the '04 Z06 for a handling issue. NeoZ06 has an '04 and doesn't have the problem. I wonder if a set of '04 shocks would help the problem.
Old Jan 13, 2009 | 01:07 PM
Steve20's Avatar
Steve20
wasn't ESC selling a transmission/diff brace for about 399 that was sure to cure the problem??
I have the same issue in an 02 Z which I have not addressed
Steve
Old Jan 13, 2009 | 01:47 PM
vsocks1's Avatar
vsocks1
Steve
ECS does sell a trans/dif brace but don't think it prevents wheel hop. I believe it only helps hold things together mechanically.
Old Jan 13, 2009 | 01:51 PM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
The car I purchased had the original SC's and the car wheel hopped really bad..
Put a fresh batch of Kumho's on and the hopping disappeared...
Old Jan 13, 2009 | 09:06 PM
Dave concrete's Avatar
Dave concrete
I heard that when you send power to the drivetrain of these cars the suspension loads up and deflection is the cause of hop.Pfadt sells a bushing kit for under 300 bucks that should help.
Old Jan 14, 2009 | 12:17 AM
drivinhard's Avatar
drivinhard
04 shocks help some, but it'll still do it
Old Jan 14, 2009 | 12:06 PM
Foxman86's Avatar
Foxman86
I heard that QA-1's help alot with this too
something I have to look into getting to help prevent the hop in my 01
I think my issue though is that I dont have enough side wall for the tire to give and the tires being real wide doesnt help either
To back wheel hop
Old Jan 14, 2009 | 01:29 PM
use2vtec's Avatar
use2vtec
I have an 04 and I get this issue from time to time as well. Its hit or miss, sometimes they just spin and sometimes I get the hopping issue. Im running Firestone Wide Ovals with roughly 10k miles on them.
Old Jan 14, 2009 | 03:28 PM
Steve20's Avatar
Steve20
Hoppin on the Michelin Pilot 2 as well
Old Jan 14, 2009 | 03:58 PM
slverbulletz06's Avatar
slverbulletz06
Nitto's 335's Also Have Hop
