FRC question
Old Jan 12, 2009 | 02:55 PM
ferrari red vette's Avatar
ferrari red vette
Default FRC question
I have a 98 AT ..
I was wondering if the Z06 Fuel Rail Covers will fit my engine without modification.
Do I have single fuel line units, or do I have two lines on the driver side?
thanks
Old Jan 12, 2009 | 03:04 PM
Munch's Avatar
Munch
St. Jude Donor '10
Have you looked under the hood?
Old Jan 12, 2009 | 03:05 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Originally Posted by ferrari red vette
I have a 98 AT ..
thanks
They will have to modified. ALL 1999+ C5's only have one slot on the FRC
Old Jan 12, 2009 | 07:29 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
So they will not fit 97-98 models
Old Jan 12, 2009 | 07:42 PM
Oldvetter's Avatar
Oldvetter
Early C5's have two fuel lines (supply and return) as opposed to just a supply on later years. The slots are for the fuel lines.
Your fuel filter is cheaper than later years because later years have the fuel pressure regulator built into the filter. Your regulator is at the engine.
Old Jan 12, 2009 | 08:07 PM
ferrari red vette
so how would i modify it to make it fit?
Old Jan 12, 2009 | 09:17 PM
Oldvetter's Avatar
Oldvetter
You could put a second slit in the one cover with a dremmel, using your current cover as a pattern.
Old Jan 12, 2009 | 09:24 PM
LoneStarFRC's Avatar
LoneStarFRC
Of course you can always just buy a '99+ C5 too.
Old Jan 12, 2009 | 10:42 PM
bencini231's Avatar
bencini231
Old Jan 12, 2009 | 11:31 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
If what you want is red fuel rail covers to fit your '98, you could either paint them yourself, or you could have one of the many vendors paint them for you. AutoBuffs can make a beautiful set in red for you, and the finish will be much nicer than the stock ones.....
http://www.autobuffs.net/
Another source is RPI Designs
http://www.rpidesigns.com/shop/item.asp?itemid=1328
To FRC question
