[Z06] Installed LG Pros - Question- please read
Old Jan 18, 2009 | 01:34 AM
spoon98hatch's Avatar
spoon98hatch
Default Installed LG Pros - Question- please read
Installed some LG pros with off road X. After driving it around and doing some readjustments to the clamps- It sounds as if it has a leak under the car. I called LG and they said that it sounds like that- kind of a ticking type of noise. I assume because they are thin walled or something i dunno. Under a load on acceleration it really sounds like ***. It shouldnt be leaking- I made sure all the slits were covered and i tightened the crap out of the clamps- Im supposed to have the car tuned on Tuesday so i need some input fast- thanks guys.
Old Jan 18, 2009 | 01:59 AM
CHIWS6's Avatar
CHIWS6
the ticking sound is normal for LT, due to the thinner wall
Old Jan 18, 2009 | 10:29 AM
Kurtomac's Avatar
Kurtomac
what header gaskets did you use?
Old Jan 18, 2009 | 10:47 AM
81c3's Avatar
81c3
I found that the clamps from LG really sucked ***.... even tightened down with my air impact gun, they wouldnt give a proper seal. I took them off, and bought some very nice 4" band clamps from Car Quest Auto. They are T-304 stainless steel and only about $11.00 ea. It solved the problem for me.
Old Jan 18, 2009 | 11:35 AM
spoon98hatch
GM LS1 Gaskets- it sounds fine at the head- plus theres no carbon anywhere
Old Jan 18, 2009 | 11:37 AM
spoon98hatch
Yeah i mean i cant tighten them down anymore with out crushing the dang piping lol- LG said that if theres no carbon anywhere on the piping that they would send me new clamps-but if they are just the same style i really dont think it will solve much.
Kurtomac's Avatar
Kurtomac
ya the LG clamps do sucketh the cocketh
im still running them but when i remove all this **** to do my clutch....might buy some 4 inch band clamps for all 100 slip fits these systems have....i wish the whole x pipe was a solid system like factory would make life a lot easier
Old Jan 18, 2009 | 11:40 AM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Get a stethescope from Autozone or wherever. You made need to get some 1/4" copper tubing for an extension.
If you do this you'll be able to listen for, and find any leaks.
Old Jan 18, 2009 | 11:52 AM
Internets_Ninja's Avatar
Internets_Ninja
You would think LG, the premier Corvette tuners, would have decent clamps with their expensive kits.....
TSP sent form fitted soft metal clamps with their header kit that seal up real nice. Maybe you can buy a set of just clamps from TSP.
Old Jan 20, 2009 | 01:56 AM
QUIKSILVERZ's Avatar
QUIKSILVERZ
i ordered a set of torctite band clamps to use with the pros. figured i would just spend the extra money for better clamps and install them with the headers.
Old Jan 20, 2009 | 08:21 AM
Kurtomac's Avatar
Kurtomac
^whered you get those clamps?
Old Jan 20, 2009 | 09:43 AM
use2vtec's Avatar
use2vtec
When the car is cold jack it up and start it. Crawl up under there and you should be able to locate the leak fairly easily.
Old Jan 20, 2009 | 09:58 AM
Millenium Z06's Avatar
Millenium Z06
Moderator
My LG clamps seal just fine, no leaks anywhere or at least no carbon stains around the joints. Headers normally have a tick and sometimes that will transfer through the exhaust and sound like it's coming from under the car.
Old Jan 20, 2009 | 11:02 AM
lbarnard's Avatar
lbarnard
I did not use the gaskets that came with mine. I bought LS2 gaskets and they sealed fine. However I have had a ticking like you said and after several removals and reinstalls due to motor issues and eventually I developed a crack in one of the gaskets and I got a "ticking". PIA but go back and make sure everything is tight and lined up there should be no ticking. Did you get the headers w/the EGR valve? Not to open up a can of worms if you did but this is the biggest problem I had with mine they both blew off and I have since fixed them but what a hassle. Happened at track events both at Road Atlanta. If you did deal with it now before that becomes an issue.
Old Jan 20, 2009 | 10:14 PM
spoon98hatch
Well i just had the car tuned today and everything looked and sounded normal so I guess its just the thin wall ticking noise i was hearing. Thanks for all the input though guys- much appreciated
Old Jan 21, 2009 | 02:08 AM
QUIKSILVERZ
verocious motorsports.
Old Jan 21, 2009 | 01:06 PM
JimbeauZ06's Avatar
JimbeauZ06
I haven't had any noise or leaks and my headers have been on and off the car multiple times.
Only problem I've had is that one shop left the bolt pointing down instead of tucked up in the tunnel like it should be, and I knocked it off , destroyed the clamp, and cracked the pipe.
To Installed LG Pros - Question- please read
