Where do u jack your c5 up?
Old Jan 20, 2009 | 06:35 AM
Tonesc5's Avatar
Tonesc5
Default Where do u jack your c5 up?
hAVENT WORKED MUCH ON MINE YET BUT THE TIME IS COMING SOON WHERES THE BEST JACKING POINTS?
Old Jan 20, 2009 | 06:55 AM
paullywalnuts's Avatar
paullywalnuts
There's 4 factory jack points. Look to the under side of the rocker panels and you'll see behind the front wheels little cut outs and inside there are slots. The rear points are foward of the back wheels. You might want to use a small piece of a 2x4 or hockey puck to avoid direct contact with the metal jack. You can also do a search on here and I know there's pics on this.
Old Jan 20, 2009 | 06:59 AM
02MillenniumVette's Avatar
02MillenniumVette
Old Jan 20, 2009 | 07:48 AM
rws.1's Avatar
rws.1
This is the best post on the topic that I have read on the Forum
http://forums.corvetteforum.com/c5-g...l?forum_id=103
Old Jan 20, 2009 | 10:26 AM
poolboy's Avatar
poolboy
I usually jack mine up in the garage
But seriously, the post above answers this question very well.
Old Jan 20, 2009 | 11:45 AM
Get yourself some jacking pucks (BMW ones work great) and install them in the factory jacking points mentioned in your owner's manual. For the rear, you can also use the crossmember if you place a piece of wood or a metal plate on the jack pad.
Old Jan 20, 2009 | 11:55 AM
chaase's Avatar
chaase
St. Jude Donor '12
I jack mine up from the rear cross member using a big floor jack. I have never bother to jack up the front. I just use ramps.
Old Jan 20, 2009 | 12:11 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Lifting without pucks. :
http://www.z06vette.com/diy_lift.php
Other links to recommended lifting & jacking locations. A hydraulic jack should NOT be placed directly under the CENTER of the front cross-member to lift the vehicle:
http://home.earthlink.net/~theadmira...tible/id5.html
http://home.earthlink.net/~theadmira...tible/id2.html
http://www.idavette.net/hib/C5diy/c5diy1.htm
Ramps other than Rhino ramps:
http://www.raceramps.com/
Old Jan 20, 2009 | 12:23 PM
eldudereno's Avatar
eldudereno
If you do get yourself some hockey pucks make sure that you also screw in an 'eye' bolt in order to keep them in position.
To Where do u jack your c5 up?
