Maintenance Question.....
Old Jan 20, 2009 | 09:57 PM
SharpCrease's Avatar
SharpCrease
Default Maintenance Question.....
My 2002 Coupe has 60125 miles. Last owner did regular service at the dealership but nothing major. He bought it with 44k from bill heard 2 years ago. Is it time for a major service or just wait a while?
Old Jan 20, 2009 | 10:15 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
I'm sure others will chime in. However, off the top of my head, the only things I could possibly suggest to you as a preventive measure is change the serp belt (good idea after 50K miles if not already done). Tranny fluid should be good to 100k but some change at 70K or even 50K. Column lock?
Old Jan 20, 2009 | 10:20 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Option #1
You can do a basic check of fluids, belts, hoses, and spark plugs. If everything's okay, you're good to go.
Option #2
Change EVERYTHING that would normally be swapped in a tune up including trans fluid, coolant flush and brake fluid.
Old Jan 20, 2009 | 10:36 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Originally Posted by TheRadioFlyer
Option #1
Option #2
I had a good chuckle about this. I think most of are one or the other. Guess I fit in option #2...:o
All good info, thanks guys
Old Jan 21, 2009 | 12:30 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
There are lots of things to check - belts and hoses as previously mentioned, you should also consider transmission fluid, differential fluid, brake system flush and fill, coolant and of course oil.
While the car is on the lift, the sway bar bushings could be greased with some dielectric grease, and the shocks should be checked for wear and leaking. If the brake pads are OEM, you could consider a swap for some new ones.
Old Jan 21, 2009 | 10:49 AM
SharpCrease
Thank you for all your replies. I've done an oil change with synthetic. I also already did a tranny fluid change. I guess all thats left is check the belts, hoses and bushings. BTW, does anyone know a shop in around Atlanta that does performance stuff?
To Maintenance Question.....
