I have a problem with my driver side window, here it goes:
When the window goes up it stops at about 1/3 the way up and seems to bind, not sure why, but seems like the window is off whatever track is used. I can raise the window with my hand during closing and it seems to roll up fine. Any feedback is greatly appreciated.
Mine used to get stuck an inch or so below the top. The cable had frayed pretty bad. I replaced the whole window regulator motor assembly for a little over $100 on the auction site. Installation was pretty simple and very quick. There are walkthroughs on here with pics.
New ones can be quite expensive. It is a common problem on our cars though. Good luck
