My Bad
Old Jan 25, 2009 | 07:37 PM
Gary Whittaker's Avatar
Gary Whittaker
Cruising
Default My Bad
I banged out 2nd gear with active handling on (My Bad). Now my dash says service tire mon system. When I hit the reset,it goes away, but when you shut off the car or start it, it comes back. What do I do next. Thanks Gary
Old Jan 25, 2009 | 08:07 PM
jrose7004's Avatar
jrose7004
I really don't know how that would mess up the tire pressure sensors.
Old Jan 25, 2009 | 09:58 PM
bencini231's Avatar
bencini231
Old Jan 25, 2009 | 11:24 PM
Doesn't make sense that it would affect the TPMS. Maybe check for a bad sensor.
Old Jan 26, 2009 | 08:46 AM
georgec114's Avatar
georgec114
Check the tire pressure...Maybe a flat or lower than 25 pounds.
Old Jan 26, 2009 | 10:53 PM
itzza427's Avatar
itzza427
Doesn't that message usually mean a sensor battery is on it's way out????
Old Jan 27, 2009 | 05:10 PM
Gary Whittaker
Cruising
They are new wheels ,tires and new sensors. Gary
Old Jan 27, 2009 | 06:05 PM
dobewillie's Avatar
dobewillie
Old Jan 27, 2009 | 06:28 PM
Oldvetter's Avatar
Oldvetter
Did you check the manufacture date on the sensors? A tire store tried to see me 6 year old tires ! If they are weak and its cold outside, they could indicate bad.
The date is shown by wheels/circles cast into the outside of the sensors with arrows pointing to month and year. Not that you can see them now.
Old Jan 27, 2009 | 06:33 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
May be a stretch but very well could be a battery gremlin issue. Try disconnecting and then reconnecting the battery.
Old Jan 27, 2009 | 07:47 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Did you try reading the codes just for fun?
Old Jan 27, 2009 | 07:50 PM
jrose7004's Avatar
jrose7004
There's a thought, or try re training your sensors!
Old Jan 27, 2009 | 10:38 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Old Jan 30, 2009 | 05:17 PM
Gary Whittaker
Cruising
Today when I got home I disconnected the battery . When I reconnected the battery everything went back to normal. Thanks for all the ideas. Gary
To My Bad
