won't start
Old Jan 25, 2009 | 11:20 PM
corvettegt's Avatar
corvettegt
Default won't start
2000 corvette 6-speed won't start. it started a couple of times in the morning then it wouldn't start. nothing came on. so i moved the battery cables & it looked ok so i pushed in the clutch to start it & i heard a pop then everything went dead again.i did this about 5-6 times
with the same results i need help!!!.
g.t.
Old Jan 25, 2009 | 11:45 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the battery to starter cable connection. Its probably come loose.
Old Jan 25, 2009 | 11:47 PM
bencini231's Avatar
bencini231
that would be a good starting point.
Old Jan 25, 2009 | 11:52 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
check your pm's!
Old Jan 26, 2009 | 12:28 AM
corvettegt's Avatar
corvettegt
Originally Posted by Silverbullet00
check your pm's!
sorry but what is a pm's
Old Jan 26, 2009 | 09:51 AM
poolboy's Avatar
poolboy
A Private Message - up near the top right corner of this window, just below where it shows your user ID, there is a link to view your PMs
Old Jan 27, 2009 | 12:23 AM
corvettegt's Avatar
corvettegt
where is the starter in relation to the battery to tighten the cables. is there any diagram available to help me. i would appreciate any help. g.t.
Old Jan 27, 2009 | 12:29 AM
Silverbullet00
I'll be up for a little bit 405.620.1297 I'll help if I can!
Old Jan 28, 2009 | 08:51 PM
corvettegt's Avatar
corvettegt
Default won't start
i'm dumber then dirt. my battery cables was loose at the battery.
i can't believe i didn't check it first.
sorry guys g.t
Old Jan 28, 2009 | 09:29 PM
poolboy's Avatar
poolboy
don't beat youself too bad = glad it is fixed and glad you got the right guidance
Old Feb 25, 2009 | 08:41 PM
Mr.Anderson's Avatar
Mr.Anderson
Need info on replacing a starter on my c5
Old Feb 25, 2009 | 09:12 PM
dgrant3830's Avatar
dgrant3830
Well, not to be a butt or anything, but it should be real simple. Disconnect the battery first. Disconnect the starter cable connections. Remove the starter and replace it with a new one. Hook everything back up in reverse order. I never had to replace my '99's starter but will assume that you need to raise the right side, probably remove the wheel for better access. Possibly the inside fender well too... someone here who's done it can better advise you.
To won't start
