Lowest profile jacking pucks?
Old Jan 26, 2009 | 02:40 AM
EFNFAST's Avatar
EFNFAST
Default Lowest profile jacking pucks?
Who sells the lowest profile jacking pucks for a C5Z?
Old Jan 26, 2009 | 03:19 AM
dachevy's Avatar
dachevy
Did you try ecklers....
Old Jan 26, 2009 | 03:59 AM
ljthe2nd's Avatar
ljthe2nd
I use BMW jacking pads. They used to cost about $6 but they have gone up, about $11 now. You can put them in and leave them in. I've had mine in for about 3 or 4 years. Here's a link
http://www.autopartsworld.com/Part.a...coded=jack-pad
click on "check availability" and you will see a pic. There are many forum members that use these.
Old Jan 26, 2009 | 06:30 AM
RonJ's Avatar
RonJ
The lowest one is probably a hockey puck.
RonJ ...
Old Jan 26, 2009 | 06:33 AM
ljthe2nd's Avatar
ljthe2nd
The BMW jacking pad is shorter than a hockey puck it's only about 5/8" or 3/4"
Old Jan 26, 2009 | 08:54 AM
bumble-z's Avatar
bumble-z
If you need something less thicker than a hockey puck, I would suggest installing rocker rail savers. You would then have a lifting point all along the length of the rockers. Good luck.
To Lowest profile jacking pucks?
