Door hinges too noisey
Old Jan 26, 2009 | 11:25 AM
CLEAR's Avatar
CLEAR
Default Door hinges too noisey
My door hinges pop and squeak too much. I have used different greases and lubricants and they only stop the noise for about a day. What are you guys using? Its embarassing to get out of a Corvette and the doors pop and screech.
Old Jan 26, 2009 | 11:36 AM
ksvette74's Avatar
ksvette74
Mine did it when I first bought it, WD-40, worked it in, sprayed again, worked it in. No problems since.
Old Jan 26, 2009 | 11:42 AM
mobman's Avatar
mobman
I use motor oil in a squirt can. Its a little more substancial and lasts longer than WD-40 and dosent leave the smegma of grease or white lube.
Old Jan 26, 2009 | 11:49 AM
bencini231's Avatar
bencini231
Ours have never squeaked or anything yet,but if they do I'll probably use some PB blaster or WD 40.
Old Jan 26, 2009 | 12:33 PM
steve8's Avatar
steve8
Mine have never been a problem, but I do a light shot of wd-40 occasionally. Nice and neat.
Old Jan 26, 2009 | 02:14 PM
TEXHAWK0's Avatar
TEXHAWK0
I think that WD40 is a little light for door hinges. It may make the noise go away, but it may not provide enough lubrication to reduce wear.
You can get white grease in a spray can that works and resists washing off.
Old Jan 26, 2009 | 02:28 PM
Wethingtonvette8093's Avatar
Wethingtonvette8093
I dont know if anyone has said this yet, WD-40 can help
Old Jan 26, 2009 | 03:07 PM
Dominic Toretto's Avatar
Dominic Toretto
What about WD40?
-Alex
Old Jan 26, 2009 | 03:12 PM
Wethingtonvette8093
Originally Posted by AlexSmith
What about WD40?
-Alex
I love it
Old Jan 26, 2009 | 03:19 PM
jobear's Avatar
jobear
Where can I get some WD 40 ?
Old Jan 26, 2009 | 03:26 PM
ProGo98's Avatar
ProGo98
Right next to the duct tape in the Repair Anything section of your local hardware store.
Old Jan 26, 2009 | 03:29 PM
Dominic Toretto
Originally Posted by Wethingtonvette8093
I love it
-Alex
Old Jan 26, 2009 | 04:03 PM
Tom/99's Avatar
Tom/99
I drip Mobil 1 on my hinges at every oil change.
Old Jan 26, 2009 | 04:11 PM
tony car4a's Avatar
tony car4a
Been using white lithium grease for years. Comes in a spray can with straw to limit spray to the specific areas. Still need to wipe off the excess as it's ugly and gets dirty but it works.
Old Jan 26, 2009 | 05:16 PM
gpotski's Avatar
gpotski
Old Jan 26, 2009 | 05:29 PM
SkyWarp's Avatar
SkyWarp
I use a product called Boeshield T9 developed by the airplane company Boeing. I use it for everything works great
Rob
Old Jan 26, 2009 | 08:03 PM
dobewillie's Avatar
dobewillie
all good ideas
To Door hinges too noisey
Old Jan 26, 2009 | 08:33 PM
Nick1's Avatar
Nick1
Try this. It appears that you have a '97 from your profile. That's enough time for the roller wheel to get grooved by the tension arm under the lower hinge area. I had that problem with my '96 Camaro which was a real PIA, but it was more visible (above the lower hinge). I gooked it up with everything imaginable and it always clicked and clunked on the drivers side. You may try forcing the wheel to turn somewhat to another spot. If you lay on the ground while a friend moves the door a bit from full open you can see the mechinism in operation. Also compare both sides, one may be worse than the other.
Old Jan 26, 2009 | 08:39 PM
RedWuken's Avatar
RedWuken
Chose your destiny!
Old Jan 26, 2009 | 08:42 PM
mag red vette's Avatar
mag red vette
WD-40 is a water displacement agent. In fact the name comes from the 40th attempt at creating the formula, and WD refers to WATER DISPLACEMENT. It's lubrication abilities are limited. Royal Purple is suppose to be coming out with a spray lubricant. My guess is that it will be superior to WD-40.
