resetting PCM
Old Jan 26, 2009 | 02:36 PM
ferrari red vette's Avatar
ferrari red vette
Default resetting PCM
does anyone reset their PCM so the fuel maps and everything can go back to default/relearn?
back when i had a chrysler 300 we did this all the time and really improved throttle response and what not
i did a search but came up with nothing, but google took me here >> http://www.digitalcorvettes.com/foru...ad.php?t=45543
Old Jan 26, 2009 | 07:26 PM
ferrari red vette
ttt
Old Jan 26, 2009 | 07:30 PM
Jet-Jock's Avatar
Jet-Jock
Nope. Don't really notice much difference in the C5 through the last 2 years (2x4 seasons) but did so on my '93 with the LT1. Maybe the technology and programs are more sophisticated now and its not necessary any more?
Old Jan 26, 2009 | 10:00 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The only reset that you can do is to disconnect the battery.
Old Jan 27, 2009 | 03:29 AM
ferrari red vette
anyone else?
Old Jan 27, 2009 | 04:14 AM
dixonk's Avatar
dixonk
St. Jude Donor '09
Disconnect the battery for about 20 minutes.
Old Jan 27, 2009 | 07:54 AM
dougbfresh's Avatar
dougbfresh
I don't think the Vette works that way-fuel maps don't change over time. Idle is learned I believe but beyond that I don't think there would be any change.
Old Jan 27, 2009 | 10:36 AM
dgrant3830's Avatar
dgrant3830
You are correct in that they don't change. The only way to really get back to stock is to have the dealer use a TechII and put in the latest and greatest software... back to stock as such. The latest updates are available to be seen on
http://tis2web.service.gm.com/tis2web
Old Jan 27, 2009 | 10:47 AM
dougbfresh's Avatar
dougbfresh
I "think" he was thinking something else. Some cars try to ADAPT to the driving style of the driver and over time change things like shift point and the like. Resetting the ECM will lose these changes. Even in those cases, I don;t think the fuel map is ever really messeed with.
Old Jan 27, 2009 | 10:57 AM
dgrant3830's Avatar
dgrant3830
Yes, there are some items in there that "learn" such as the idle and so on.
Old Jan 27, 2009 | 12:53 PM
ferrari red vette
correct, that what i am thinkin about...
Old Jan 27, 2009 | 01:46 PM
dougbfresh's Avatar
dougbfresh
Then think again.
Old Jan 27, 2009 | 01:47 PM
ferrari red vette
Then think again.
uhh ok... so dont do it?
Old Jan 27, 2009 | 05:09 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
In addition to idle learning, Long Term Fuel Trims definitely do change over time, and will reset to zero after a battery disconnect or PCM reflash.
LTFTs usually stick around zero on a stock engine, so no difference doing this on an all stock car...but once things like air filter and headers (or more) go on, trims start to go positive and richening up the car to compensate for the additional airflow it's moving. (this is a big part of what a tune corrects - getting those corrective trims back to around 0 is the goal).
When people in that situation (positive trims) disconnect the battery, they usually do notice a difference right after the reset. Throttle response may be better, idle smoothness may be better, and WOT will feel stronger...but it's all because car is running leaner than it was.
Over time, the trims will go back to being positive, and the car will gradually start to feel sluggish again.
If anyone finds their car acts this way after a reset, it's a pretty good indicator that a tune would be beneficial.
Old Jan 29, 2009 | 11:07 PM
ferrari red vette
ttt
Old Jan 30, 2009 | 03:48 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
If you ad a intake you might see a slight benefit otherwise it will pretty much just learn itself back in about 50 miles
To resetting PCM
