HP Difference? 97-00 vs 2001+
Old Jan 27, 2009 | 08:09 PM
gleds's Avatar
gleds
Default HP Difference? 97-00 vs 2001+
Just as the title says. Is there a significant difference in HP in 97-2001 year models verus 2001-2004? Anyone put them on a dyno to compare?
Old Jan 27, 2009 | 08:13 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
5 hp
Old Jan 27, 2009 | 08:29 PM
borlavette's Avatar
borlavette
for 01 and up
Old Jan 27, 2009 | 08:34 PM
Bad97ta's Avatar
Bad97ta
the ls6 intake is the difference of 5 hp
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I went from a 2004 to a 1997 and I was so disappointed with the power loss that I ordered a high performamance hood seal from Southern Car Parts. Now I blow the doors off those late model guys.
Old Jan 27, 2009 | 08:46 PM
dobewillie's Avatar
dobewillie
Old Jan 27, 2009 | 10:29 PM
DefenderC5's Avatar
DefenderC5
Originally Posted by borlavette
for 01 and up
yup, but about 25 more ft/lbs of torque as well (with the manual trans). LS6 intake, different cam etc. It's not a deal breaker though, all years are good. A few mods or a cam swap would erase any difference between the two.
Old Jan 27, 2009 | 11:22 PM
rebelheart's Avatar
rebelheart
Also the Z06 exhaust manifolds became standard on all LS1's and helped a bit!
Old Jan 28, 2009 | 08:50 AM
gleds's Avatar
gleds
thanks for the replies! Interessting to know. I planned on long tubes, LS6 intake, and a cam so it looks like i will be taking care of all the short comings of my 97
Old Jan 28, 2009 | 11:37 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Slap on a blower and it cures all short comings of any model C5
Old Jan 28, 2009 | 11:39 AM
warren s's Avatar
warren s
Dont forget the throttle body air-foil!
Old Jan 28, 2009 | 01:48 PM
For coupe and vert - 5 hp difference. For Z06, the '01 had 385 hp and the '02-04 had 405 hp.
Old Jan 29, 2009 | 04:38 PM
Wop1's Avatar
Wop1
All good choices, and if you want to make the most of all that, heads are in order, whether aftermarket or ported LS6, with a matching port job on the intake. A good tune and it will know your sox off.
Old Jan 29, 2009 | 07:50 PM
borlavette's Avatar
borlavette
so what was the increase from the 01 compared to the 02-04 what did they do, what upgrades
Old Jan 29, 2009 | 11:11 PM
C5XTASY's Avatar
C5XTASY
2001 Z06 cam was different than the 2002-2004 Z06 cam, and also the heads, or, at least the valves (sodium filled) and springs were different.
Also, the 2001-2004 blocks (same used for the LS6 and LS1) were modified for less pumping losses than the 1997-2000 blocks.
Another little known point of difference, in the LS1s, was that the 2000 cam was the most aggressive of any C5, 1997-2004. So, if you have a 2000 without precats, you may have one of the strongest stock C5s made.
Ed
To HP Difference? 97-00 vs 2001+
