Rim Width
Old Jan 30, 2009 | 01:32 AM
vettemiker's Avatar
vettemiker
Default Rim Width
I have some stock thin spokes,17/8.5 front and 18/9.5 on rear,wanting to go with the zo6 sizes 17/9.5 and 18/10.5.I have the firestone Firehawk tires 245/45 zr17 front and 275/40zr18 rear,it looks like the rears will fit fine on the wider rims but what about the front.It looks like it is half an inch from the specs of fitting.any help. THanks
Old Jan 30, 2009 | 01:36 AM
c5blkvetteguy's Avatar
c5blkvetteguy
You might have to buy new rims and sell me your old ones. lol.
Old Jan 30, 2009 | 02:15 AM
8VETTE7's Avatar
8VETTE7
I've read of guys running the stock non-Z06 tires on the Z06 rims until they needed to replace tires. The .5 inch difference stretches the specs but unless you plan on a lot of road racing you should be OK. The effect on the tire is to pull center of the tire in more and hence wear the outer edge.
One alternative is to spring for the Z06 tire sizes and sell the tires you now have. By the way you may not find the Z06 sizes in run flats if that is a concern to you.
Another alternative is to find some Z06 rims in the stock C5 widths. I believe there are some knock off Z06 rims available in C5 widths. At least there used to be.
Old Jan 30, 2009 | 08:10 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I would be more concerned about compromising safety. Stretching the tire beyond a recommended rim width, will affect how the car handles.
It could also have a negative effect on the speed rating of the tire, if it's stretched beyond the recommended limits on a wider rim.
Don't do it.
Old Jan 30, 2009 | 02:41 PM
vettemiker's Avatar
vettemiker
Default Rims
The rims I am looking at are the deep dish thin spokes,I seen a pair of chrome ones on ebay with 9.5 front and 10.5 rears,they dont make them in normal sizes.
Old Jan 30, 2009 | 04:22 PM
Sasso1's Avatar
Sasso1
Don't do it.
I thought I would also do that when I bought C6 Z06 rims in stock C5 Z06 sizes, but the stock C5 tires looked too stretched. Take a look. Even my wife thought it looked like crap and I ended up buying new C5 z06 tire widths the next day!
Old Jan 30, 2009 | 05:06 PM
Personally, I would go with the regular Z06 size tires on those rims. I'm not a fan of stretching tires beyond what is recommended for a wheel width.
Old Jan 30, 2009 | 05:38 PM
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
I have the same issue just got my C5 Z06 wheels and have decided to just buy new tires all the way around. I'll just keep the old set with 10,000 miles on them for when I take the car out to the track and tear them up.
To Rim Width
