LS1 Oil consumption????
Old Feb 2, 2009 | 05:42 PM
LT1vette's Avatar
LT1vette
Default LS1 Oil consumption????
Hi...Are LS1's known to use oil? I'm using a quart evry 4-4500 miles on an engine with 115,000 miles on it.
Is this normal?
TIA
Old Feb 2, 2009 | 05:53 PM
wcsinx's Avatar
wcsinx
All engines use oil.
LS1 probably more than most because they have a tendency to atomize it and then suck it through the PCV.
Old Feb 2, 2009 | 06:48 PM
sami85L98's Avatar
sami85L98
Just put a quart of oil and move on, get over it, some alternate solutions but they r not guaranteed to solve this issue, even though a qrt of oil every 3-4.5k looks normal to me.
Old Feb 2, 2009 | 07:07 PM
dobewillie's Avatar
dobewillie
try a catch can from one of the vendors here
Old Feb 2, 2009 | 07:35 PM
Jacks02's Avatar
Jacks02
If you're using Mobil synthetic 5W-30, consider a thicker specification.
Old Feb 2, 2009 | 07:46 PM
ColeTrain'sC5's Avatar
ColeTrain'sC5
i used to have this issue until i went to a catchcan. I was getting about a quart every 3500 miles so when i got the catch can i thought maybe i'd be emptyin' the can every oil change. i haven't been suckin' more then an 1-2 oz each oil change. Idk if i got lucky and the oil PCV valve was just toast or what. It works great though Also my LS1 intake manifold was DRIPPING oil almost when i pulled it off. Replaced with a great, clean LS6 and it's bone dry in there
Old Feb 2, 2009 | 08:54 PM
Patman's Avatar
Patman
Is this normal?
Mine has 102k on it and is also using about a quart every 4000 miles. I'm not too worried about it though, as long as it doesn't get any worse than that.
Old Feb 2, 2009 | 10:07 PM
painkiller's Avatar
painkiller
Default Oil issue
Had the same problem,that is until I tried this......
http://www.mobiloil.com/USA-English/...l_1_0W-30.aspx
Maybe you'll see an improvement too!
Old Feb 3, 2009 | 12:51 AM
LT1vette's Avatar
LT1vette
Ummmm....This is WHY I have the problem. I just changed to 0W30 Mobile....
I've heard some initial problems when switching over from conventional. I'll wait for the next oil change to see if there is an improvement....
THX
Old Feb 3, 2009 | 01:32 AM
chadman's Avatar
chadman
I don't believe that to be excessive oil consumption, in fact I think it is great for a car with 115000miles. I wouldn't worry about any consumption of less than a quart per 750 to 1000miles.
Old Feb 3, 2009 | 07:54 AM
dieseldave56's Avatar
dieseldave56
Default Oil consumption issues........
http://www.rjsmith.com/gm-894549.html
The basis of the LS1 oil consumption issue is blow-by from the crankcase caused by poor cylinder bore tolerances and the thin flat faced piston rings. Out of round and tapered cylinder bores along with driving styles ( operating at high engine speed with no load) increased the oil consumption in the LSx engines. This oil issue came to a head with the introduction of the LS6 .
You don't indicate if you have manual or auto tranny. That also makes a difference in oil consumption.
The GM TSB allows for a band-aide fix for 1999-2001 LSx engines with that band-aide following thru on 2002-2004 M/Ys production.
The acutal fix is with the Gen 4 LS2 block , where the siamized cylinder bore cooling passeges were opened up to eliminate the hot spots that the Gen 3 engines experienced ( and which contibuted to the out of round cylinder bore condition that then over taxed the thin, flat faced, low tension piston rings , hence the blow-by).
A direct answer to your question of oil consumption of 1 quart in 4000 miles is that is normal or better.
Old Feb 3, 2009 | 09:13 AM
jrose7004's Avatar
jrose7004
Is your car a 2001?
Old Feb 3, 2009 | 10:30 AM
LT1vette's Avatar
LT1vette
[QUOTE=dieseldave56;1568799887][URL="http://www.rjsmith.com/ The basis of the LS1 oil consumption issue is blow-by from the crankcase caused by poor cylinder bore tolerances and the thin flat faced piston rings. Out of round and tapered cylinder bores along with driving styles ( operating at high engine speed with no load) increased the oil consumption in the LSx engines. This oil issue came to a head with the introduction of the LS6 .
A direct answer to your question of oil consumption of 1 quart in 4000 miles is that is normal or better.[/QUOTE]
My vette is a 99 6 spd that I drive conservatively and my truck, 2003 Sierra 5.3 is an auto overdrive with 3.73 rear. The truck I drive at no more than 2000 RPM to obtain some sort of mileage figure with and the Vette I drive to work on the highway in 6th gear 30 miles.
They both use more than what I would call "normal" amounts of oil.
THX
Old Feb 3, 2009 | 10:55 AM
I'd say that is not bad at all. Heck, my '00 with 11K miles was using a quart every 1200 miles. Had the dealer do the ring replacement and problem solved.
Old Feb 3, 2009 | 11:02 AM
jimcork1's Avatar
jimcork1
99 Bought new 80,000 miles 10W30 M1 used oil changed at 100% on computer never more than 1/2 qt low. Yes it does get driven on the track.
Old Feb 3, 2009 | 11:40 AM
lh4x4's Avatar
lh4x4
I have never had an engine after 1995 that ever used oil in the three to 7,500 mile change intervals. At the full mark at the start and at the full mark at the change.
To LS1 Oil consumption????
