[Z06] Temp up 10 degrees
Old Feb 2, 2009 | 11:21 PM
RaleighSS's Avatar
RaleighSS
Default Temp up 10 degrees
Well I installed a set of ported and polished set of heads on the 02 Z06 and have noticed the oil temps up about 10 degrees. Anyone else seen this? They are from Texas Speed and Performance. Maybe all the cutting has made some jackets thinner drawing the heat up. The coolant temps seem to be about normal..... I think this is going to hose me out at VIR so may have to move to a external cooler..... Just looking to see if anyone else has installed a set of heads like this and had the same results
Old Feb 2, 2009 | 11:24 PM
Roger Z06's Avatar
Roger Z06
Check the thread below you and see what texas speed heads he installed ... title is Oops lost a piston or something...
Old Feb 2, 2009 | 11:26 PM
ptindall's Avatar
ptindall
Don't know man, but if you drive hard enough you're going to need an oil cooler sooner or later anyway.
Old Feb 3, 2009 | 09:59 AM
lbarnard's Avatar
lbarnard
No doubt more HP/TQ lead to more heat; I don't have your setup but I did see my oil temps creep up when I started modding the car; I did install an Accusump and Ron Davis EOC radiator;
Old Feb 3, 2009 | 11:40 AM
vms4evr's Avatar
vms4evr
+1. If you track the car any amount and are serious about it. An oil cooler should be high on your list. I put my money into things that protect the investment I have first. Oil cooler, brake ducts, regular fluid changes. Lots of spare rotors and shelf liner
Old Feb 3, 2009 | 06:11 PM
GlenRoseFireFighter's Avatar
GlenRoseFireFighter
what kind of thermostat do you have? Add some WaterWetter =)
Old Feb 3, 2009 | 06:28 PM
ptindall's Avatar
ptindall
He's talking about oil temp, not coolant temp. Water wetter in the oil sounds like a bad idea.
Old Feb 4, 2009 | 04:06 PM
GlenRoseFireFighter
yes, but if you lower he block temp, that will help with the oil temp
Old Feb 5, 2009 | 10:42 AM
Bigstik's Avatar
Bigstik
More HP/Tq means more friciton and more heat.
To Temp up 10 degrees
