[Z06] Hey Higgs, question
Feb 4, 2009 | 05:54 PM
Hey Higgs, question
My Z06 is electron blue. So what oil should I run?
Feb 4, 2009 | 06:39 PM
Feb 4, 2009 | 06:49 PM
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Royal Purple, what else!
Feb 4, 2009 | 07:17 PM
Feb 4, 2009 | 08:01 PM
hahaha umm well what type of gas do u run??
Feb 4, 2009 | 09:26 PM
St. Jude Donor '08-'09
Quote:
Originally Posted by
slverbulletz06
It always depends on the time of day you are filling up. Which of course leads to the next question, full tank, 7/8ths, 3/4, 5/8ths, 1/2, or 3/8ths? Is it ever ok to go below 3/8ths? Is so, what type of gas is ok to go below 3/8ths?
Feb 4, 2009 | 10:36 PM
Feb 4, 2009 | 10:51 PM
stig-zzz
Depends if you have BSMs or not.
Feb 5, 2009 | 10:35 AM
last run
when should i run the ac
What brand tires are on your car, and do you use the HUD??
Toyo;yes---between the hours of 8 a.m. and 11 a.m.
Goodyear; no ---between the hours of 3 p.m. and 6 p.m.
Others; yes ---between 11 a.m. and 2 p.m.
Everything else ---never
Feb 5, 2009 | 01:57 PM
From: www.modular-concept.com www.flatoutimaging.com
Olive Oil
Extra Virgin is usually better for Supercharged cars.
Feb 5, 2009 | 03:01 PM
What viscosity blinker fluid should I run and tire valve caps?...ok ok.
Feb 5, 2009 | 06:28 PM
Do most drivers keep the original air in their tires or go aftermarket?
Feb 5, 2009 | 06:34 PM
26myles
Aftermarket
Feb 5, 2009 | 06:48 PM
GubuZ06
What do u torque the tire valve caps to after you change from winter air to summer air???
Well..........
Feb 5, 2009 | 07:17 PM
FLATOUT
Aftermarket
now some one is going to chime in about putting helium in their tires....
it did take 10 pounds off my car.
Feb 5, 2009 | 10:54 PM
What's better? Stage 2 Muffler Bearings or Stage 3?
I would like to maintain stock-like driveability!!
Feb 6, 2009 | 09:39 AM
im thinking of adding a 3 speed wiper motor and removing the brakes and using the e-brake to cut down on weight along with oil injection to the air box for better top end power
Feb 6, 2009 | 09:57 PM
Ya know if you soak down your tires wiff WD40 durring the winter you will not git any dry rott.
Feb 7, 2009 | 02:59 AM
Skypilot797
Well..........
lol
Feb 7, 2009 | 09:31 AM
bobdobb
bobdobb do i have to take the wheels off to fully coat them???If so how does the wheel come off ?? i tried and tried i just cant pull them off there glued on i think...if i jack it up do i need a wheel puller or can i use a heat gun to soften the glue >> my wife said i should try to remove those thingies i tried but my pliers wont work maybe vise grips
