[Z06] dreaded column lock
Old Feb 6, 2009 | 09:18 PM
JustinZook's Avatar
JustinZook
Default dreaded column lock
It happened today. My 04Z had told me its column lock time. WHat are the best bypasses i can get? pref one with easy install?? Thanks
Old Feb 6, 2009 | 09:22 PM
vms4evr's Avatar
vms4evr
Read this:
http://forums.corvetteforum.com/c5-t...ky-please.html
and this:
http://forums.corvetteforum.com/c5-t...gm-merged.html
or just go buy this:
http://www.corvettesofhouston.com/pr...d1033fef4c14e4
Old Feb 6, 2009 | 09:39 PM
JustinZook's Avatar
JustinZook
thanks for your help my friend!!
Old Feb 6, 2009 | 10:40 PM
THE TECH's Avatar
THE TECH
Not to be rude, but why doesn't anyone search before asking one of the most commonly asked questions on this forum????
Old Feb 6, 2009 | 10:56 PM
TEXHAWK0's Avatar
TEXHAWK0
Anyone that knows it is the "dreaded column lock", must know the alternatives for a fix.
The GM harness, or aftermarket, are all the same as far as ease of installation. You just plug them into the existing connectors.
If would be interesting to know if you have had any of the recalls done, and what system you currently have in place.
Old Feb 6, 2009 | 11:07 PM
TheDingo's Avatar
TheDingo
^ If you decide to do that, I'm almost positive you can have the Chevrolet service dept run your VIN and they can tell you the recalls that have been done to your vehicle and what sysem you have in place.
Old Feb 7, 2009 | 04:47 AM
NOLA's Avatar
NOLA
thunder racing clb 1o minute install get in doneeeeeeeeee ..........
Old Feb 7, 2009 | 01:49 PM
JustinZook's Avatar
JustinZook
i just wanted to get peoples opinions... I have an 04Z it has gone in for the recall. i have tried everything, none of the little tricks are working.
Old Feb 7, 2009 | 01:57 PM
JustinZook's Avatar
JustinZook
recall done in march of 06
Elect Column Lock
.8 96 performed column lock campaign
harness k 2.195
Old Feb 7, 2009 | 06:06 PM
bob guzzy's Avatar
bob guzzy
My recall was done just before I got it, but I still put a bypass on it for the peace of mind.
I got one here off one of the vendors for 50 it took a few mins to put in and it was over.
Old Feb 7, 2009 | 06:19 PM
RKGarner's Avatar
RKGarner
Had the Dealeship do the recall last Saturday before my lock failed. They installed a new column lock. Also got a free oil change.
Old Feb 7, 2009 | 07:12 PM
JustinZook's Avatar
JustinZook
i just bought the bypass from corvettes of houston now i have o wait for shipping!! damn i should have planned ahead
Old Feb 9, 2009 | 05:58 PM
HWY HNTR's Avatar
HWY HNTR
lol we would of thought the 20000 threads recommending getting the bypass kit would stop these new threads.
Old Feb 10, 2009 | 12:09 PM
fxdl's Avatar
fxdl
just this morning i finally installed my clb from corvettes of houston. was getting nervous about getting stranded somewhere. easy install other than that damn connector under the dash that i was swearing at before i finally got it undone. tight area. for some reason me and electrical connectors don't get along well. especially in tight areas.
one question though. has anyone ever had one of these aftermarket clb's go bad and left them stranded? just wondering.
Old Feb 10, 2009 | 01:12 PM
Last C5's Avatar
Last C5
I had exactly the same problem with my 01Z that had the recall already done on it. Turned out the factory recall had gone bad and needed to be replaced. Installing the Houston bypass before I had the recall redone did nothing to solve the problem. Why, I don't know, that's beyond my electrical/electronic capabilities.
Old Feb 10, 2009 | 02:22 PM
CGartist's Avatar
CGartist
There is a fuse you can pull that will fix it..it worked for me. NOWHERE ONLINE did I find out about this...Ryan at RPM fixed it for me.
Old Feb 10, 2009 | 04:06 PM
JustinZook's Avatar
JustinZook
i havnt got my clb yet but i was messing around and i detached i believe it is the harness that they installed when they did the recall, and i plugged in the old one that was left in its original place, and sure enough it worked, but for how long, who knows? im still waiting on my CLB to get here
To dreaded column lock
Old Feb 10, 2009 | 10:21 PM
KENCO's Avatar
KENCO
St. Jude Donor '11
Because each individuals case is different and important to that person, and always in need of guidance and help.................or it could just be that there is a small troll or dwarf inside there steering column.
Old Feb 11, 2009 | 04:40 PM
JustinZook's Avatar
JustinZook
i do agree with ya!
Old Feb 12, 2009 | 08:24 PM
TEXHAWK0's Avatar
TEXHAWK0
If you reconnected the actuator and it works, then at least that tells you the problem is a bad harness relay.
Does your column still lock?
If not, then at least you do not have to worry about the column locking, just the BCM getting the right feed back. The actuator could fail at any time, or it could work for years.
In any case, the CLB should solve the problem.
