Sunvisors
Old Feb 7, 2009 | 07:00 AM
howard goldberg's Avatar
howard goldberg
Default Sunvisors
Where to buy new sunvisors. And do you have to buy the complete set or can it come apart. Thanks
Old Feb 7, 2009 | 08:16 AM
k0ts's Avatar
k0ts
What is wrong with the old ones?? If the mirror is falling away from the visor, you can
fix that..
Here is a good GM parts house.. http://www.gmpartshouse.com/
Old Feb 7, 2009 | 08:52 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here check these out They look pretty awesome and will make for a great custom look
http://forums.corvetteforum.com/c5-g...interiors.html
Thanks,Matt
Old Feb 7, 2009 | 02:23 PM
Jet-Jock's Avatar
Jet-Jock
Yes you can buy them as individuals from dealer service or online gm parts retailers.
Consider getting a new set of the parts that holds them secured. They wear over time and it takes just a few minutes to install new ones. What a difference in grip. They are only a few dollars each.
Old Feb 7, 2009 | 03:12 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
If they have the droopy-ear syndrome or just don't look good, you can get them recovered.
I had both of mine done after installing the Homelink for about $100. All new fabric and inside stuff.
Old Feb 7, 2009 | 03:24 PM
PETE O.'s Avatar
PETE O.
fix that..
This is where I bought mine. Good discount and great service. I only needed the left side and it was noooo problem.
Gene is a great guy and a huge help. Excellant vendor!!!!!!!
Old Feb 7, 2009 | 06:10 PM
howard goldberg
Default sunvisors
Thanks for all the info, yes mine have droopy-ears. How do i take them off. Thanks
Old Feb 8, 2009 | 02:37 PM
Stickman81's Avatar
Stickman81
There are some instructions out there somewhere...
I basically -
* Flip the sunvisor down and disconnect it from the "inner" snap location.
* Wrapped some electrical tape around the post near the 90 degree bend.
* Used small screw driver pressed into the "Tab" of the housing with one hand.
* Using the other hand, move the sunvisor "Outwards" (towards the side windows) watching the tabbed housing. The arm of the sunvisor provides the rotational force to dislodge the housing.
* Gently fish out the connector for the vanity lights.
I hope this helps.
Click for the BIG picture.
Old Feb 8, 2009 | 03:04 PM
Arfboy's Avatar
Arfboy
I had to take my visors off this week. Driver's side came off easily, but the passenger side was impossible. I destroyed the plastic piece with the tab in the process. Does anyone know if this one piece is replaceable or do I have to buy a whole new visor?
Old Feb 8, 2009 | 03:13 PM
Jet-Jock's Avatar
Jet-Jock
Yes you can buy new lock rings. Check with your GM dealer or GM online retailer.
Old Feb 8, 2009 | 04:33 PM
howard goldberg
Thanks for your help. hope i dont break it
Old Feb 8, 2009 | 04:36 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Check out the Parts for Sale Forum. I see new ones pop up there from time to time.
To Sunvisors
