GM Bra Installation Question
Old Feb 7, 2009 | 11:36 AM
Sailon's Avatar
Sailon
Default GM Bra Installation Question
The GM Bra mounting hardware consist of two types of snap screws. The first type is a machine thread which screws into a rubber bushing.
The second type is simply a self tapping screw.
The installation instructions have you remove two of the screws holding the wheel well liner to the front fascia and remove the dzus fasteners that they thread into. You then insert the rubber bushing into the 5/16 hole.
My question is why does GM have you input a rubber bushing instead of just using a snap screw with a self tapping screw in the wheel well? Under the fascia they have you use the self tapping screws. I have seen some threads where folks go to a local marine store and pickup some #8 screw-snaps which screw right into the existing dzus fasteners which seems easier. Neither way is hard but seems GM must have a reason since the snap screw w/ rubber bushing is more expensive than just a snap screw w/ self tapping screw.
Old Feb 7, 2009 | 12:01 PM
Have no idea why they did the setup like that. Would have been much easier just to use the screw without the rubber piece.
Old Feb 7, 2009 | 12:06 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
When I installed mine I used all screws and not the rubber, I did use a bit longer screws though.
Old Feb 7, 2009 | 02:13 PM
steve8's Avatar
steve8
If I remember correctly, I didn't use any of the rubber bushings and had no problem.
To GM Bra Installation Question
