I just bought a 1999 covertable corvette. I've only had it for a week. We were driving it and it overheated. Does anyone think that it might be the thermostat? Also the oil pressure gauge is all the way to 80, even before you start the motor. I just turn the key on and it goes to 80psi. I need some help please. I hope it can be fixed. I took it back to the dealer. I dont think it had any dex-cool mix in it either. i hope I didn't buy a lemon. It is a beautiful car.
The oil pressure is the sender. Do a search and you will find much discussion on it. It is a bit hard to get to to replace, requires removal of the intake manifold.
Check the thread under C5 Tech. There are a couple of good write-ups, including how to relocate the sender using a bit of tubing and some fittings, so subsequent failures don't require the intake manifold removal. Here's the URL: http://forums.corvetteforum.com/c5-t...-relocate.html
Also per Bill Curlee, check the grounds. Being close to the ocean, the likelihood of corrosion is higher. I have to agree that this one is probably the sender, but weak grounds will cause the electronic gremlins to pop up all over.
for the over heating problem I would also suggest that you reach up in front of the radiator (from underneath) and check to make sure there's no buildup of leaves and plastic bags - the airflow on C5s will suck things up in there. blocking the airflow.
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
This would be the very first thing I'd check....
And your oil pressure issue is simply the sending unit. As the others have said, there are DIY tips in C5 Tech - otherwise it would be a fairly simple fix for an experienced mechanic, in our shop it's about two hours of labor give or take....
I doubt if you bought a lemon - these are fairly common issues with the C5. Post some pics of the car when you get a chance....we all love pics even though we know what they look like!
I also had a hair line crack in my coolant tank that caused pressure leak down. Tank is about the same price as the thermostat.
I have to tell you guys. My car is back on the road. It was the thermostat. YEAAA!!!! All I have to do now is the oil pressure sending unit. Thank you again so much for everyones help and suggestions. You made me feel a whole lot better. good information. I love this website.
I bet your car is not overheating, they run hot, see here:
C5 Cooling Fans Operation
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
Your oil pressure sensor is probably toast. If with the ignition switch on, and the engine off, it shows oil pressure, it is your sensor.
