strange drl (?) condition...
Old Feb 9, 2009 | 09:10 AM
BosqueVette98's Avatar
BosqueVette98
Default strange drl (?) condition...
Recently I noticed that when I have my headlights on, the passenger side front, yellow marker light is not working. The drl lights work fine, the turn signal works fine, it's only when I have the headlights on that the light won't work...
Is there bulb that is burnt out in the housing I'm missing?
Thanks!
Old Feb 9, 2009 | 09:48 AM
tracks03's Avatar
tracks03
Assuming you're looking at the lights while the car's running or switched on, have you just turned on the parking lights without anything else on? Does that light not work then?
If it does not, I believe that the DRL bulb needs replacing. It's a 4157 or 3157 that has two circuits, one for the bright DRL or turn signal, and one for the dimmer marker lamp.
Old Feb 9, 2009 | 10:06 AM
mcgilles's Avatar
mcgilles
the bulb in there is a dual filament. sounds like your parking light filament is burned out. strange, due to the DRLs its usually the turn signal filament that goes first.
easiest way to change that bulb is through the front brake vent duct. the owners manual says to go through the access panel, well that will work, but its a pain! push the brake vent duct out of the way and you can look right in and see the bulb. push the tab in and rotate and it will come out.
then do a search for how to disable your DRLs and drive in peace knowing that you and you alone control you car's lights :-)
Old Feb 9, 2009 | 10:21 AM
Change the bulb and all should be back to normal.
Old Feb 13, 2009 | 08:32 AM
BosqueVette98
thanks for the replies! I changed the buld out, but within a day, I had the same condition. The DRL works, but the parking light burned out...
Old Feb 13, 2009 | 08:33 AM
BosqueVette98
yes, that's correct...
Old Feb 13, 2009 | 12:39 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
If the filament blew once again, I'd check the wiring as best you can, looking for a grounded spot. Seems that a short is causing the bulb to burn out. Good luck.
To strange drl (?) condition...
